apexi Posted July 11, 2014 Share Posted July 11, 2014 I wasn't exactly sure where to put this thread, so I just threw it in the general fourth gen legacy section. Got in my car tonight after leaving the grocery store, and heard the sounds below as I started to drive away. If you don't want to listen to the sounds clips, it was a scraping/screeching sound while I drove around, regardless of whether I applied the brakes or not. I had no idea what the sound was, and first thought the dust/splash shield behind the rotor had cracked/bent and was hitting the rotor itself, or maybe a brake pad clip rubbing against the rotor. Outside car, easier to hear. http://home.comcast.net/~apexigsx/subaru/brakerock1.m4a Inside car, a little harder to hear. http://home.comcast.net/~apexigsx/subaru/brakerock2.m4a Long story short, a small rock was stuck between the back of the brake rotor, and the rotor dust/splash shield. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2014 Share Posted July 11, 2014 Been there, done that. Next time it happens you'll know what it is. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Redryan98 Posted July 11, 2014 Share Posted July 11, 2014 nice. hopefully this prevents someone from taking the car to a shop and getting a huge diag fee or for parts the car doesn't need. Link to comment Share on other sites More sharing options...
