Max Capacity Posted June 24, 2014 Share Posted June 24, 2014 I think the muffler delete with going catless will be to loud. When ever I get around to it, I'll put a cated DP on my mufferless Spec B. The wagon without mufflers was to loud for a DD. It still has the stock mid pipe and magnaflow knock off mufflers, but is catless. It's quiet except at WOT. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted June 24, 2014 Share Posted June 24, 2014 I think the muffler delete with going catless will be to loud. When ever I get around to it, I'll put a cated DP on my mufferless Spec B. The wagon without mufflers was to loud for a DD. It still has the stock mid pipe and magnaflow knock off mufflers, but is catless. It's quiet except at WOT. agree. my wagon has catted invidia dp, catless up, no mufflers. It's loud. Made me giggle when I'd wind up the rpms tho. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LeggoMyLeggy Posted June 25, 2014 Author Share Posted June 25, 2014 ^ gonna try that setup, seems most cost effective. What do you guys recommend as far as headers? ELH or UEL? Is there a noise/ power difference? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2014 Share Posted June 25, 2014 Oh come on, you haven't seen this, http://legacygt.com/forums/showthread.php/equal-length-headers-and-why-you-should-get-em-226678.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LeggoMyLeggy Posted June 25, 2014 Author Share Posted June 25, 2014 Honestly I had not, thanks for putting me in the right direction. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2014 Share Posted June 25, 2014 Your welcome, I guess I spend to much time here... Your in NJ, contact Mike at www.AZPinstalls.com buy from him. He'll take good care of you, great customer service. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LeggoMyLeggy Posted June 25, 2014 Author Share Posted June 25, 2014 Appreciate all the help guys, especially Max Capacity. Link to comment Share on other sites More sharing options...
HDZ32 Posted June 25, 2014 Share Posted June 25, 2014 I'm looking for mine to be a bit louder too, I have a noncatted DP and Stromung full exhaust, no cats. But it's still pretty quiet. Will an UP help me out with that? I've also heard a good UP makes the turbo a little louder too? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2014 Share Posted June 25, 2014 I'm looking for mine to be a bit louder too, I have a noncatted DP and Stromung full exhaust, no cats. But it's still pretty quiet. Will an UP help me out with that? I've also heard a good UP makes the turbo a little louder too? A up will be good for the turbo, the stock one in your year has a cat in it that can come loose... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HDZ32 Posted June 25, 2014 Share Posted June 25, 2014 A up will be good for the turbo, the stock one in your year has a cat in it that can come loose... I've heard horror stories about it :/ that's why this is next on my list for sure, and a tune of course. Does it increase exhaust or turbo noise at all? Link to comment Share on other sites More sharing options...
LeggoMyLeggy Posted June 26, 2014 Author Share Posted June 26, 2014 IS there a way to just gut it and get the same result? And I think it helps spool a bit Link to comment Share on other sites More sharing options...
boxkita Posted June 26, 2014 Share Posted June 26, 2014 I'm looking for mine to be a bit louder too, I have a noncatted DP and Stromung full exhaust, no cats. But it's still pretty quiet. Will an UP help me out with that? I've also heard a good UP makes the turbo a little louder too? swapping the UP isn't going to make much different at the tailpipe. YOu want loud, remove the mufflers. You want everyone to notice you, drive in the upper half of the rpm range (on boost) Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
LeggoMyLeggy Posted June 26, 2014 Author Share Posted June 26, 2014 Im not really going for obnoxious honestly, But i hear WRX's and STI's in my area constantly that just seem so much louder even though they have the same mods as I do FTMP. I'd like to be in on the fun too, I suppose. Link to comment Share on other sites More sharing options...
