E.E.R.P. or Emergency Engine Rebuild Plan
Hey guys, I know that some of these Legacys are notorious for burning up valves or having turbo issues that tear up your insides or even the occasional head gasket leak. So I have been thinking, when one of those things happens to me, will I be ready? So I have decided that I want to make a parts plan for when I have to yank my engine to do some work, the only problem is that I have no idea what I should do! I would like to keep all parts and labor under $5000 so I don't plan on going too crazy with parts, but I am thinking some higher compression pistons(my car is CNG so that is my reasoning for that), some good strong valves that will hold up to less lubrication and Higher heat, and head gaskets.
But what about bearings or other things like that? What else should I think about doing to avoid having to pull my engine again for a good long time, because really what I'm going for is reliability. What would be the best parts for my list(part number included if possible)? Keep in mind that my car runs on CNG so I may want to go with different internals but really I'm not sure if that really matters too much. Let me know if you have any suggestions. Thanks Guys!
Read through this (edit: so Max Capacity isn't hurt. The first thread here is his)
http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html
Once you are done read Mr.Tris and Wasp's build thread. That should give you a very good idea of what you will need based on your goals.
Mr.Tris
http://legacygt.com/forums/showthread.php/tris-build-thread-223568.html
Wasp
http://legacygt.com/forums/showthread.php/wasp-build-thread-215759.html
and this for reliability modifications
http://legacygt.com/forums/showthread.php/reliability-modifications-178342.html?t=178342
Oh sorry, nevermind then...:)
Op, there may be other options for CNG, but I would have hoped you've checked out those sites.
There was someone on here, I just tried to look for his thread that did this conversion last year, haven't found it yet...
Engine Build - Click Here
Is this the thread you are looking for? :)
http://legacygt.com/forums/showthread.php/50-mpg-06-legacy-gt-cng-natural-gas-build-218910.html?t=218910&highlight=cng
Ive looked around a little bit, for the most part I would like some insight on the pros and cons of higher compression pistons and ported and polished heads and so on for someone in my situation(CNG).
