Scottyd73 Posted June 2, 2014 Share Posted June 2, 2014 Engine wire harness. Do I need to remove the intake manifold to do so? Witch mean I need to replace the gaskets too Link to comment Share on other sites More sharing options...
johnegg Posted June 3, 2014 Share Posted June 3, 2014 you can get an intake manifold with wiring for about $65 from http://www.car-part.com sort by zip code to see what is close. then sort by price to see what is cheap. Link to comment Share on other sites More sharing options...
Osei Posted June 3, 2014 Share Posted June 3, 2014 +1^ You can also just pull the harness. Just cutting zip ties, and unhooking electricals. Easier with manifold loose. Any 95-98 2.2 or 96-98 2,5 will do. O. Link to comment Share on other sites More sharing options...
r3v_v3ng3 Posted June 5, 2014 Share Posted June 5, 2014 I've done it without removing the intake manifold Link to comment Share on other sites More sharing options...
