bg. Posted May 29, 2014 Share Posted May 29, 2014 Hey there, I have an 06 LGT which has been protuned by a local shop, and have the magnaflow catback with a 3" mid pipe and a 2.5" y-pipe into dual mufflers. What I want to do is keep my 3" mid pipe, and run one single 3" muffler and have a shop weld a pipe up to it from the mid. Would it be necessary to retune when changing my exhaust setup like this? Or would it still flow relatively the same and I could just reset the ecu and let it relearn? Thanks!! Link to comment Share on other sites More sharing options...
RallyMachine Posted May 29, 2014 Share Posted May 29, 2014 My sti friend has always told me that if you change a headlight in these cars you need a retune lol. But in all seriousness, if you have the tools to do pulls yourself and pull learning views you should be able to tell if you need a refreshed tune. I would venture to guess that it will not be that far off, but when I changed header/UP combo for a different brand as well as upgrading to a Perrin turbo inlet my tune was noticeably off. No knocking, but spool/boost and a CL load comp table my previous tuner did were affected Link to comment Share on other sites More sharing options...
liljonson Posted May 30, 2014 Share Posted May 30, 2014 no retune for changing a muffler setup Link to comment Share on other sites More sharing options...
bg. Posted May 30, 2014 Author Share Posted May 30, 2014 I didn't think so either, dp and headers is what makes the big difference, I just though from going from 2 mufflers and a y pipe to one can would make a change in back pressure Link to comment Share on other sites More sharing options...
RallyMachine Posted May 30, 2014 Share Posted May 30, 2014 All I can say is that if you do change you should at least keep an eye on the state of the tune if at all possible. I had a friend with a '13 WRX blow his motor on the stock tune in under 10k miles and he was running around with no mufflers... just sayin'. Link to comment Share on other sites More sharing options...
