http404 Posted May 25, 2014 Share Posted May 25, 2014 Question... About one year ago I was in an accident where I rear-ended someone at about 15-25 mph (my fault... I know...) Had hood and bumper replaced and radiator I think. Not much damage it seemed as I drove away from the accident all the way home, and also the the auto-shop 1/2 hour away. When I picked up the car, I noticed that the idle seemed lower, but it didn't affect anything, so I just ignored it. About a week ago it seems to affect steering performance while stopped. It makes the steering wheel shake when the rpm drops too low around 500-750, and I should point out that if I rev it a little it does not happen. Any thoughts or insights would be appreciated. Thanks, Link to comment Share on other sites More sharing options...
apexi Posted May 26, 2014 Share Posted May 26, 2014 How much total driving time do you think you have done since you have picked up the car? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 26, 2014 Share Posted May 26, 2014 ECU reset. Drive it more, as it learns things will smooth out. Link to comment Share on other sites More sharing options...
http404 Posted May 26, 2014 Author Share Posted May 26, 2014 How much total driving time do you think you have done since you have picked up the car? At least 1 year (20k miles). Link to comment Share on other sites More sharing options...
http404 Posted May 26, 2014 Author Share Posted May 26, 2014 ECU reset. Drive it more, as it learns things will smooth out. I'll try this today. Link to comment Share on other sites More sharing options...
ssbtech Posted May 26, 2014 Share Posted May 26, 2014 Intake air temp sensor damaged on the MAF? Link to comment Share on other sites More sharing options...
ssbtech Posted May 26, 2014 Share Posted May 26, 2014 I'll try this today. He's not suggesting you reset the ECU, but rather that the ECU might have been reset during the repair causing the roughness. But that roughness would have evened out with a few miles of driving. Link to comment Share on other sites More sharing options...
http404 Posted May 27, 2014 Author Share Posted May 27, 2014 Intake air temp sensor damaged on the MAF? I'm not sure how to tell if this is damaged or not. Do you have any suggestions? Anything I can check that would indicate if it was damaged or not? Thank you so much for your help Link to comment Share on other sites More sharing options...
ssbtech Posted May 27, 2014 Share Posted May 27, 2014 Does it start up with a low idle or does it start high and settle down as it warms up? Link to comment Share on other sites More sharing options...
apexi Posted May 27, 2014 Share Posted May 27, 2014 I'm tempted to say reset the ecu again even though that shouldn't be the problem after a year. How many miles on your spark plugs? Might just be a weird coincidence that the plugs are getting worn. Link to comment Share on other sites More sharing options...
http404 Posted May 28, 2014 Author Share Posted May 28, 2014 I'm tempted to say reset the ecu again even though that shouldn't be the problem after a year. How many miles on your spark plugs? Might just be a weird coincidence that the plugs are getting worn. Actually, I purchased some spark plugs about a month ago and just haven't put them in. I don't know, but have reason to believe, that they have never been changed and the car has 130,000 miles on it. Think this could be it? I'll try to change them today. Link to comment Share on other sites More sharing options...
http404 Posted May 28, 2014 Author Share Posted May 28, 2014 Does it start up with a low idle or does it start high and settle down as it warms up? When the car starts up it idols at over 1000 RPMs until it warms up. It's when it is already warmed up and idling like steering in the parking lot or in the driveway without moving, that it will happen. Link to comment Share on other sites More sharing options...
apexi Posted May 28, 2014 Share Posted May 28, 2014 Actually, I purchased some spark plugs about a month ago and just haven't put them in. I don't know, but have reason to believe, that they have never been changed and the car has 130,000 miles on it. Think this could be it? I'll try to change them today. It's hard to say since the problem seemed to have started after the accident, but it's definitely a possibility. Subaru calls for 30k intervals on our spark plugs which may be a bit excessive, but I wouldn't want to push them past 60k. Post #144 in the thread below shows how worn the plugs can get if they are not changed. http://legacygt.com/forums/showthread.php/2-5i-spark-plug-tutorial-117769p4.html The poster of reply #144 said the person wasn't having any driveability issues, which is surprising with a plug that worn. Link to comment Share on other sites More sharing options...
