MAP Posted May 25, 2014 Share Posted May 25, 2014 I thought I would share a pic of my blue Gates timing belt at about 10k miles. It's got about 12k miles now. As people have mentioned, the blue coating does come off and transfer onto the idler pulleys. Since I hadn't seen any pictures, I'm sharing a pic of mine. I thought it was pretty significant material transfer. You can feel the difference in height when you run your finger nail across it. If I were to do this again, I would get the regular black belt. Don't know why they would design something that would do this. Hopefully in time it comes off the belt and idler completely without causing a problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 26, 2014 Share Posted May 26, 2014 Yep, that's why I didn't put one on my car. black is beautiful, hey, can I say that... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted May 26, 2014 Share Posted May 26, 2014 Mine has been on for about 30k. No problems. I noticed that transfer a while ago, but the consensesus is that it's not an issue. Link to comment Share on other sites More sharing options...
JJr Posted May 26, 2014 Share Posted May 26, 2014 I agree Black is beautiful. I will not be using the Kevlar belt because of this issue! I can't see any good coming from a build-up of ? on the machined idler pulley! Ihope you have no issues down the road. Link to comment Share on other sites More sharing options...
Gex Posted May 26, 2014 Share Posted May 26, 2014 Just checked mine. 1700 miles on Kevlar belt no noticeable transfer yet. Link to comment Share on other sites More sharing options...
Brian3676 Posted May 27, 2014 Share Posted May 27, 2014 I have the blue belt. Very little transfer after 10k. I cleaned the idlers off with a razor and no issues. I have seen people with lots of transfer but i think it was because they did not adjust the guards correctly. Link to comment Share on other sites More sharing options...
MAP Posted May 27, 2014 Author Share Posted May 27, 2014 Mine is an automatic. There are no guards to adjust. I'll check it periodically... No way i'm risking using a sharp blade near the belt. I sent an email to Gates, we'll see if they respond. If so, I'll post here. Link to comment Share on other sites More sharing options...
MAP Posted May 28, 2014 Author Share Posted May 28, 2014 Manufacturer doesnt seem to think its a problem. Maybe they figured users dont take a look after installation until its time to change out. Response from Gates: Color transfer can and will happen, however it does not compromise the belt itself CHRIS Automotive Aftermarket Applications Research GATES CORPORATION 1551 Wewatta St Denver, CO 80202 Telephone + 1.303.744.5192 http://www.gates.com Link to comment Share on other sites More sharing options...
evildriver Posted May 28, 2014 Share Posted May 28, 2014 "Does not compromise the belt itself"... What about the rest of the parts it interacts with? Link to comment Share on other sites More sharing options...
lee07 Posted May 28, 2014 Share Posted May 28, 2014 Why I went with the black belt when I rebuilt my engine. Why people choose to put this belt on instead, I do not know. Link to comment Share on other sites More sharing options...
JJr Posted May 28, 2014 Share Posted May 28, 2014 "Does not compromise the belt itself"... What about the rest of the parts it interacts with? I was not concerned with the belt either Link to comment Share on other sites More sharing options...
starionesir Posted May 28, 2014 Share Posted May 28, 2014 Almost 18k on my gates belt including all the accessory belts and no issues. Same similar thing was going on with the dsm crowd. Had some transfer but no issues were caused by it. Link to comment Share on other sites More sharing options...
SilverLegs Posted May 31, 2014 Share Posted May 31, 2014 The husband and I run Blue gates belts all the time. no issues. *shrug* Link to comment Share on other sites More sharing options...
