witek Posted May 15, 2014 Share Posted May 15, 2014 Hey guys, My 05 leggy gt limited is making a weird creaking noise, can't figure out what it is. It goes away with higher rpm but is prevalent during idle. Sounds like its coming from the alternator but I'm not sure. I've looked at countless videos with weird engine noises and couldn't find one that sounds like mine so I posted one on YouTube. Sorry about not rotating it, did it from the phone and didn't really bother to change that. http://youtu.be/OiBlwBnITuA Help! Link to comment Share on other sites More sharing options...
MrTris Posted May 15, 2014 Share Posted May 15, 2014 Your first post was not only a legit question but also a link to a video? And we didn't even have to ask you to post one?? Dude, welcome! Link to comment Share on other sites More sharing options...
MrTris Posted May 15, 2014 Share Posted May 15, 2014 I'm gonna guess belt and/or pulley(s). . . ? Does it get louder/increase with RPMs/revs? Link to comment Share on other sites More sharing options...
MAP Posted May 15, 2014 Share Posted May 15, 2014 Try tightening the belt a little bit to see if it makes a difference, could be loose. They tend to stretch with time. Not sure why these engines dont have automatic tensioners... Link to comment Share on other sites More sharing options...
heiche Posted May 15, 2014 Share Posted May 15, 2014 you could also try removing the accessory belts, and try spinning each pulley by hand. if you feel/hear any roughness, that could be your culprit. also, just checking, how's your oil level? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
witek Posted May 15, 2014 Author Share Posted May 15, 2014 Oil level is about 75%, this noise was unaffected after an oil change. The noise increases in frequency with higher rpm (pointing towards something with the belt) but disappears with an rpm of about 2k+. Not sure if related, but I get a bit of belt slip/noise when I'm in reverse and at full lock. Definitely could do with a bit of a tighten. (Noise has been happening a while, thought it was caused by frigid temperatures that seem to make death rattles and squeaks with any moving part.) Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 15, 2014 Share Posted May 15, 2014 What heiche says, but if I were a betting man I'd say that alternator is on its way out. BTW, you should rustproof your car. Link to comment Share on other sites More sharing options...
SonnyLegacyGt5speed Posted May 15, 2014 Share Posted May 15, 2014 Can someone please help me diagnosis this noise my car is making. I did my best and tired to look for the source and I think it's coming from downpipe where the turbo meet or down pipe to mid pipe. I'm not to sure and could be wrong with this. This is why I asked for help. I tired to upload the video but it's taking for ever. Tried to uload the URL but keep getting error. So here's the link. https://www.youtube.com/watch?v=dRfCH93ovV0&feature=youtube_gdata_player PLEASE HELP!!! A first Owner #Subbie #Scubby lover. Thanks Link to comment Share on other sites More sharing options...
witek Posted May 15, 2014 Author Share Posted May 15, 2014 Removed the belts and spun the pump, alt ac and idler. All seemed fine without any rough spots or noise. Tightened them back up and started the engine. No noise so far, but this noise has a tendency to go away and reappear. Hoping it was a case of under tightened belts as they seemed a bit loose before I took them off. Thanks for the input guys, I'll let you know if it comes back. Link to comment Share on other sites More sharing options...
__raj Posted May 17, 2014 Share Posted May 17, 2014 Ours made a similiar sound it was a throw out bearing in clutch. Does pressing clutch make any difference when it happens? Link to comment Share on other sites More sharing options...
SonnyLegacyGt5speed Posted May 19, 2014 Share Posted May 19, 2014 when I press on the clutch noise still stay the same does fade or change or anything. In the vid it was a stand still with a little rev and the noise gets louder with that little rev. On a roll shifting on low rpm under 3k is pretty noticeable inside and out. But on high rpm the noise fade and it's not noticeable. Link to comment Share on other sites More sharing options...
