Kodybarbera Posted May 9, 2014 Share Posted May 9, 2014 I have a rear rattle at lower RPMs. it seems to be coming from the passenger side. I know my turbo heat shield is missing two bolts but I don't think that's it seeing as I only hear the rattle under 2k rpm. is it maybe another heat shield? or possibly the exhaust? any input would be greatly appreciated. thanks! Link to comment Share on other sites More sharing options...
WhiteMonster06 Posted May 9, 2014 Share Posted May 9, 2014 Need a little more info, what mods have you done if any? Link to comment Share on other sites More sharing options...
silen7guardian Posted May 9, 2014 Share Posted May 9, 2014 I have a rear rattle at lower RPMs. it seems to be coming from the passenger side. I know my turbo heat shield is missing two bolts but I don't think that's it seeing as I only hear the rattle under 2k rpm. is it maybe another heat shield? or possibly the exhaust? any input would be greatly appreciated. thanks! Could a rattle come from shaft play? Or is that only when the compressor wheel completely fails? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 9, 2014 Share Posted May 9, 2014 Get under the car and inspect all the heat shields. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Kodybarbera Posted May 9, 2014 Author Share Posted May 9, 2014 that is supposed to say weird not rear. but anyways. car is stock. seems to be coming from up front. I will have to pull the down pipe and check for shaft play but wouldn't I hear that at higher rpm too? Link to comment Share on other sites More sharing options...
GTPpilot Posted May 9, 2014 Share Posted May 9, 2014 Uh oh, if it's the wastegate Link to comment Share on other sites More sharing options...
FJuan Posted May 9, 2014 Share Posted May 9, 2014 Heat shield missing 2 bolts, huh? It's the heat shield. Had the same problem with mine. Took it off and problem solved. Take it off and see if that helps. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Kodybarbera Posted May 10, 2014 Author Share Posted May 10, 2014 well missing one bolt and the head of another is snapped off (whoops) but I'll have to try and take it off. and what about the wastegate? Link to comment Share on other sites More sharing options...
FJuan Posted May 11, 2014 Share Posted May 11, 2014 What about the wastegate? Taking the heat shield off is not going to affect the wastegate. The only issue of taking the heat shield off is a little more radiant heat going up toward the intercooler. Replace the heat shield or buy a turbo blanket. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Kodybarbera Posted May 11, 2014 Author Share Posted May 11, 2014 no, someone commented before you and said about the wastegate Link to comment Share on other sites More sharing options...
JJr Posted May 11, 2014 Share Posted May 11, 2014 My engine rattle post: http://legacygt.com/forums/showthread.php/engine-rattle-216473.html?t=216473&highlight=engine+rattle. Link to comment Share on other sites More sharing options...
FJuan Posted May 12, 2014 Share Posted May 12, 2014 no, someone commented before you and said about the wastegate Take the heat shield off and comment back. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Kodybarbera Posted May 12, 2014 Author Share Posted May 12, 2014 I won't get to that probably for a few day.. out of blaster and don't wanna snap more bolts Link to comment Share on other sites More sharing options...
Max Capacity Posted May 12, 2014 Share Posted May 12, 2014 My heat shild on my wagon is cut shorter so I don't use the hole where the bolt broke years ago. I also have the big heat shield over the mid pipe removed. I also have the shield from the manifold by the oil filter removed and replaced the DEI heat wrap. I think you can see it on my click here link somewhere. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
