stepinrazor Posted May 7, 2014 Share Posted May 7, 2014 The rear passenger window no longer rolls down. Both the drivers and actual door window is not working. Where should I start looking to fix? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 9, 2014 Share Posted May 9, 2014 I would say remove the doorskin first because its very likely you'll end up in there eventually. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 9, 2014 Share Posted May 9, 2014 What I'd like to know before I tear into my 2008 rear doors is if you can modify the mechanism to allow the rear windows to wind all the way down? Link to comment Share on other sites More sharing options...
stepinrazor Posted August 10, 2014 Author Share Posted August 10, 2014 I ended up taking out the door skin, put the switch from the rear passenger side to see if it worked and it didnt. So it wasnt the switch, I ended up ordering a used motor online and replacing it. It was pain and I ended up scratching my tint but got it fixed for about $65 in parts. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted August 11, 2014 Share Posted August 11, 2014 Did it look like you could modify it so it rolled down all the way? Link to comment Share on other sites More sharing options...
stepinrazor Posted August 14, 2014 Author Share Posted August 14, 2014 Did it look like you could modify it so it rolled down all the way? I dont think so, it would require some serious fab work. Link to comment Share on other sites More sharing options...
