HFT_Eliot Posted April 29, 2014 Share Posted April 29, 2014 So I'm going to be looking at a 2005 LGT 5 Speed. It has 122k miles. New timing belt, seals, water pump, coolant, spark plugs. It has newer tires and 70% left on the breaks. It also has a VF52 just put on it, Spt cold air intake, Megan Racing up and down pipe and a stage 2 tune. I should also mention that it is owned by a mechanic and is said to be very well taken care of. I can also post pictures if needed. Anything I should look for? Problems with the 05? Fair pricing? Thanks! All advice is gladly taken! Link to comment Share on other sites More sharing options...
Max Capacity Posted April 29, 2014 Share Posted April 29, 2014 Ask him if the banjo filter has been removed that feeds the turbo ? If yes, that's a good thing. Ask why was the turbo replaced? Has he been the only owner ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HFT_Eliot Posted April 29, 2014 Author Share Posted April 29, 2014 He is the second owner and I don't think the banjo filter is removed. How hard is it to do so? As for the turbo since turbo seals can go out at 100k he just happened to find a good deal on the turbo brand new and got it. Everything is in working condition because this is his current dd. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 29, 2014 Share Posted April 29, 2014 Sounds like a good car. Ask when the last time the tranny and diff fluids were changed and what he used. Subaru Extra-S is the best thing to use, Amsoil Severgear and Motul 300 are others that are ok, most everything else will cause issues. Oh, the banjo is a little PITA but doable with a stubby 17mm ratcheting box wrench, there's a DIY on here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HFT_Eliot Posted April 29, 2014 Author Share Posted April 29, 2014 Not sure but I can do that myself. What would you suggest it the first thing I should do to the car? and also should I worry about the miles or is that fine since alot of things have been replaced. Thanks for the help! Link to comment Share on other sites More sharing options...
