killzone Posted April 18, 2014 Share Posted April 18, 2014 Got the legacy back from garage new rad and alt , temp keeps rising after a few mins even with aircon on high and really hot , if I rev the car hard temp drops.any ideas. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2014 Share Posted April 18, 2014 its probably low coolant or air bubbles in the lines... Link to comment Share on other sites More sharing options...
Bassnectar Posted April 18, 2014 Share Posted April 18, 2014 yup they never burped it. you need a 2$ coolant funnel you place on the rad and set the heater to high and let the engine run through a few fan cycles. while putting coolant into the funnel as air escapes the level in the funnel will go down. squeeze the upper rad hose at the same time to speed things along. or you can bug the shop for not doing this properly the first time. Link to comment Share on other sites More sharing options...
killzone Posted April 18, 2014 Author Share Posted April 18, 2014 The shop has had an ear full , and I told them if there is any problems, they can sort it FREE OF CHARGE Link to comment Share on other sites More sharing options...
killzone Posted April 19, 2014 Author Share Posted April 19, 2014 ok update , i followed the burped routine , temp stays normal untill i rev it then it rises , i did notice with the aircon on high it was not warm or hot, i checked the top pip on the rad hot and bottom cold , so this points me to the termostat, i also notice the expantion thank was filling up , not sure if it was over filled at the garage. The mechanic at the garage rang me to see how i got on , he thinks the HG is blown and that i should remove the termostat and see if it still heats up . any ideas, icant get a termostat untill tue as its a bank holiday here. If it is the hg , is it worth doing on a 99 car . Link to comment Share on other sites More sharing options...
Idaho subaru Posted April 19, 2014 Share Posted April 19, 2014 Are the fans coming on? Why did it need a new radiator? Was it overheating before? Cold lower hose means no flow, did they change the thermostat? If so that could be the problem, as it is likely they did not use a Subaru thermostat. If burping helped a little, you're likely not done, keep burping. Fill, squeeze, repeat. Link to comment Share on other sites More sharing options...
Okayer2570 Posted April 19, 2014 Share Posted April 19, 2014 Pop open the thermostat housing. See what they put in there. There is a huge diffrance in t-stats from generic aftermarket to OEM . after I replaced my busted radiator I got a basic t-stat from Autozone. ALL BAD! Car started over heating until I pulled the t-stat. Replaced with OEM and the car is back to normal. Sent from my SAMSUNG-SM-N900A using Tapatalk Link to comment Share on other sites More sharing options...
killzone Posted April 19, 2014 Author Share Posted April 19, 2014 sorry yes the fans are running , , i got the car cheap as its rad was cracked, they did not replace the thermostat, i will do that nxt week , i was told by its owner that it did not have a overheating problem ,so i took him at his word. the machanic that was working on it got fired, bad workmanship , he put the rad in , thats where it ends . i will remove the old thermostat and retry .i find it unusual that another mechanic said remove the therma and see what happens. Thanks Guys Link to comment Share on other sites More sharing options...
Okayer2570 Posted April 19, 2014 Share Posted April 19, 2014 Have them pressure test the system. Make sure there are no bad head gaskets Sent from my SAMSUNG-SM-N900A using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted April 20, 2014 Share Posted April 20, 2014 Have them pressure test the system. Make sure there are no bad head gaskets unfortunately this.. Link to comment Share on other sites More sharing options...
killzone Posted April 20, 2014 Author Share Posted April 20, 2014 I am try ing to find a indapendant subaru mech , near where i live no liik so far , just incase its the HG, So far the car , new rad and second hand alt , plus car pick up and delivery has set me back 770 euros , not bad good alloys and tyres cabin in good nick , front bumber needs some work or replacement. SO FINGERS CROSSED ITS NOT THE HG Link to comment Share on other sites More sharing options...
Headtrauma89 Posted April 21, 2014 Share Posted April 21, 2014 Yeah, I'd try the t-stat first. But if your blowing bubbles in your overflow... it's a sign of HGs. It's worth doing if you do it yourself. I do them all the time, really not that bad Link to comment Share on other sites More sharing options...
killzone Posted April 21, 2014 Author Share Posted April 21, 2014 There are no bubbles forming in the expantion tank @ the moment Link to comment Share on other sites More sharing options...
johnegg Posted April 21, 2014 Share Posted April 21, 2014 do not mess with the t-stat unless you install an original subaru part. an ''oem'' from the parts store will not work. then fill and BURP the system. do a search for 'how to fill and burp your cooling system'. Link to comment Share on other sites More sharing options...
killzone Posted April 21, 2014 Author Share Posted April 21, 2014 I will get a original from Suburu this week Thanks again to you all. Link to comment Share on other sites More sharing options...
