SubieAA Posted April 13, 2014 Share Posted April 13, 2014 I had a stuttering problem about 1.5 years ago and while taking it to the dealer for full tune-up, they mentioned new ECu recommended upgrade from Subaru. I figured I could reset my base map with my Accesport if I wanted to, and had them chip the ECU. The problem turned out to be misfiring which I fixed finally with a coil replacement, but what are my options for getting back to a stage 1 Cobb base map? Trying to reset the base map gives me ER HC on the dash. I can only overlay a map and that is not working properly with the base map installed by dealer. Link to comment Share on other sites More sharing options...
rob-2 Posted April 13, 2014 Share Posted April 13, 2014 Did you unmarry your Cobb before the work? Link to comment Share on other sites More sharing options...
SubieAA Posted April 24, 2014 Author Share Posted April 24, 2014 No. Complete rookie. I had used it for stage 1 upgrade a long time ago. What are my options now? Link to comment Share on other sites More sharing options...
SubieAA Posted April 24, 2014 Author Share Posted April 24, 2014 Thanks for the reply. Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 24, 2014 Share Posted April 24, 2014 Call Cobb and tell them what happened and see if they can unmarry your AP. Link to comment Share on other sites More sharing options...
SubieAA Posted April 24, 2014 Author Share Posted April 24, 2014 I called them and they will give me $100 I think toward a new v3.. Link to comment Share on other sites More sharing options...
SubieAA Posted April 24, 2014 Author Share Posted April 24, 2014 So the key is the un-marry? I will look into it.. Link to comment Share on other sites More sharing options...
