The_Josh Posted April 9, 2014 Share Posted April 9, 2014 Hi guys I'm rebuilding a 96 DOHC 2.5 and one of the cylinder heads has suffered some abuse in its past life. I'm not having good luck finding a replacement head for it. What other years of ej25 heads will be applicable that will bolt right up? Thank you! Link to comment Share on other sites More sharing options...
Osei Posted April 11, 2014 Share Posted April 11, 2014 96-98 DOHC, plus the 99 DOHC from a Legacy. I just don't know if you can mix the HLA's from the 96 with the shim system of the others. Compression ratios are the same, tho the 96 required premium. Hopefully someone else will chime in. O. Link to comment Share on other sites More sharing options...
