vanman Posted March 31, 2021 Share Posted March 31, 2021 It turns out the lathe ideal wasn't so good. The harden nub in the bucket would just ground down the stone and eventually clog up. A better solution was to use the drill press and randomly move the bucket so that not not just one area would get the grinding, like a random orbital sander. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 1, 2021 Share Posted April 1, 2021 It turns out the lathe ideal wasn't so good. The harden nub in the bucket would just ground down the stone and eventually clog up. A better solution was to use the drill press and randomly move the bucket so that not not just one area would get the grinding, like a random orbital sander. I'm no machinist, but have known a few and watched them do there thing at where I worked for 40 years. Did you use any cooling fluid while machining ? You might be better off to just buy the correct pieces instead of risking your engine to save a few bucks... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
