PearlBlueGT Posted April 4, 2014 Share Posted April 4, 2014 So my mother starter her car in the morning and it was shaking like it has bad vacuum leak, there's no CEL. I know she filled up a couple days ago, maybe bad gas? What could be causing this, where could I start checking? Link to comment Share on other sites More sharing options...
Tehnation Posted April 4, 2014 Share Posted April 4, 2014 check fuel trims and fuel pressure. Link to comment Share on other sites More sharing options...
chato Posted April 4, 2014 Share Posted April 4, 2014 check the turbo inlet for a leak, that seems to be everybody else's problem lately. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 5, 2014 Author Share Posted April 5, 2014 check fuel trims and fuel pressure. What should fuel trims be like? Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 6, 2014 Author Share Posted April 6, 2014 So I was able to pull code today, its P0302, cylinder #2 misfire. Do they sell ignition wires separate for these cars or do I have to buy coil with it as well? Link to comment Share on other sites More sharing options...
Tehnation Posted April 6, 2014 Share Posted April 6, 2014 No ignition wires, check coil pack and spark plug. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 6, 2014 Author Share Posted April 6, 2014 I got the coil pack out, how do I check with multimeter, there are three contacts on coil. Spark plug looks good. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 7, 2014 Author Share Posted April 7, 2014 Is this part (circled in red) supposed to ground to the engine? It's metal and when I turned on engine it would send spark to engine if I held it close by. Link to comment Share on other sites More sharing options...
Tehnation Posted April 7, 2014 Share Posted April 7, 2014 Swap the coil pack with another cylinder and see if the code changes to that cylinder. Link to comment Share on other sites More sharing options...
Tehnation Posted April 7, 2014 Share Posted April 7, 2014 Fuel trims should be within +- 5. Link to comment Share on other sites More sharing options...
AF_3C2 Posted April 7, 2014 Share Posted April 7, 2014 I have the same problem- rough idle, can hear a miss at idle, and throws a Cylinder 2 misfire code every now and then. Other than that, the car pulls fine and appears to run clean under acceleration, so I was going to start looking at the intake/TGV gaskets for a leak. Dealer wanted to tell me the miss is normal for this generation LGT and the plugs are not to be touched until the 105k service. /rolls eyes Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 8, 2014 Author Share Posted April 8, 2014 Weird thing but I've swapped coils between cylinder 1 and 2 and reset CEL and then I turned on engine to see if CEL would come back. Car idled rough for 1/2 a minute or so and then started running great again! I went to gas station and topped off tank (2.3 gallons) and its been running great on way back from gas station. Link to comment Share on other sites More sharing options...
