Bubbaray Posted April 2, 2014 Share Posted April 2, 2014 I have a 96 legacy that will randomly not start. You turn the key and get power to everything but the car wont start not even crank over. This happens minutes after the are is started and or the first start of the day. Sorry not a car guy. I've tried using the micro switch under the dash with the car in the on position and that seemed to work a couple times and other times when that doesn't work I just let the car sit for 10-15 minutes then try again and bam the car starts. Any thoughts would be greatly appreciated and thanks in advance. Link to comment Share on other sites More sharing options...
sunny5280 Posted April 2, 2014 Share Posted April 2, 2014 This is a complete SWAG but when my 1997 experienced a similar problem it ended up being a loose battery connection at the battery terminal. The cable in question had a connector which was bolted to the cable and that bolt came loose. My current 1997 has a similar set up. I didn't notice it immediately as it is covered by a rubber cover on the battery terminal. Can't say this is your problem but it's quick and dirty to check. Link to comment Share on other sites More sharing options...
GEORGEROV Posted April 2, 2014 Share Posted April 2, 2014 Hi Bubba , Unfortunately with older cars they require continual maintenance due to wear and tear , rust , etc and if you are not into diy then it can become expensive and irritating . As Sunny has said its just by fiddling about under the hood making , remaking connections and doing routine servicing yourself that a lot of problems are avoided that age brings . Sorry I cant be of more specific help to you but your problem could be as simple as a dodgy connection to a sensor going bad and really the only way to solve it is to follow a logical path starting from a complete service of the car . Link to comment Share on other sites More sharing options...
sunny5280 Posted April 3, 2014 Share Posted April 3, 2014 Just noticed you're in Denver. Perhaps I can give you a hand. I'm not a mechanic but know a little bit about cars. Link to comment Share on other sites More sharing options...
Idaho subaru Posted April 3, 2014 Share Posted April 3, 2014 Has the starter ever been replaced? 1st vote is for a loose or bad/corroded battery cable. 2nd vote is for a starter on its last leg. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 3, 2014 Share Posted April 3, 2014 +1 for checking the ground cable on the battery..if thats good id check out the starter as stated Link to comment Share on other sites More sharing options...
Headtrauma89 Posted April 3, 2014 Share Posted April 3, 2014 I have a 97 2.2 that's doing the same thing. I replaced/ rewired the battery terminal connections because that's what my initial thoughts were too. It was fine for a few days, then it happened again. My next try is the starter. I think it has a dead spot in it and it's kind of Russian roulette on where it is when I try to start it Link to comment Share on other sites More sharing options...
kurtis9813 Posted April 3, 2014 Share Posted April 3, 2014 I had the exact same problem on my 95 legacy l. Turned out to be the crankshaft sensor(located under the altenator) it was on its way out and ever sinced i replaced it it has started everytime Link to comment Share on other sites More sharing options...
LongHiway Posted April 3, 2014 Share Posted April 3, 2014 Or, try moving the shifter (assuming it is an automatic). Every once in a while my car has the same symptoms, the neutral saftey switch doesn't understand the car is in Park and won't start. Moving the shifter (not even out of Park) is enough and the car starts right up. Link to comment Share on other sites More sharing options...
johnegg Posted April 4, 2014 Share Posted April 4, 2014 try the easy , cheap, stuff first. bad battery connections, they must be clean and tight. this causes more ''no start'' situations than all other causes combined. if it is an auto trans, try starting it in N instead of P. or just wiggle the shifter. have both the battery and the alternator chaecked for free at a parts store. but be prepared to say NO if / when they offer to install a battery. you may need one, but you may not. do not assume they are correct. their goal is to sell you something. starter solenoid contacts, try tapping on the starter solenoid with a broom stick when it will not start. tap, do not BANG. the starters them selves are very hardy and almost NEVER fail. but the contacts in the solenoid that connects power to the starter get old, worn and charred. you , or a decent mechanic, can replace them.($12 in parts) another possible solution which i think is easier, is to add a relay to the starter ignition circuit. this sends strong power to the starter solenoid directly from the battery, eliminating power loss due to old bad dirty wire connectors and components. hth Link to comment Share on other sites More sharing options...
