DonnyJagaru Posted March 31, 2014 Share Posted March 31, 2014 Regardless of how careful I am when changing oil, some of the old oil ends up inside the heat shields when I remove the oil filter. Then I get a whiff of burning oil for the next week or so when I come to a stop after driving for a little while. This smell really makes me feel nauseous. Is there a trick to changing the filter so this doesn't happen? Link to comment Share on other sites More sharing options...
1fast4by Posted March 31, 2014 Share Posted March 31, 2014 Slip a piece of cardboard up there as a splash shield. Link to comment Share on other sites More sharing options...
apexi Posted April 4, 2014 Share Posted April 4, 2014 One of the best ideas I read on this forum or another forum is to use a solo cup when you remove the oil filter. I haven't gotten a chance to try this yet but it sounds like it should work nicely. Some people also say you could use a bread bag when you remove the filter, but I think the plastic cup is the way to go. Link to comment Share on other sites More sharing options...
Picky1 Posted April 7, 2014 Share Posted April 7, 2014 Got to get one of these...it looks like a great idea. A lot of folks on BITOG use them, they can be ordered on Amazon. Or a DIY solution would be to cut up a milk jug or something to make a funnel. Link to comment Share on other sites More sharing options...
lingling1337 Posted April 7, 2014 Share Posted April 7, 2014 I save the large heavy duty plastic bags that brake rotors and stuff come in for this. Or you can use a gallon ziploc but those are a little flimsier. What I do is barely crack the filter loose then cover it with the bag and twist the rest of the way off, so the filter and some oil fall into the bag. Double-bag it if you get oil on the outside of the bag. I never make a mess this way. Im gonna try the solo cup though, that actually sounds perfect. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 8, 2014 Author Share Posted April 8, 2014 Some good ideas here, I'll try the cup out in a few months. Thanks. Link to comment Share on other sites More sharing options...
