boattlebot Posted March 24, 2014 Share Posted March 24, 2014 after running my car on the highway to commute to work, (i wont lie i dont really hesitate to go triple digits) when i stop or have my windows down a little im smelling gas. i always smelled it a tiny bit i just thought it was from WOT. but its been getting worse reguardless of WOT and its getting me a little concerned. i dont want my leggy to catch fire any ideas what the hell is goin on? Link to comment Share on other sites More sharing options...
mailman Posted March 25, 2014 Share Posted March 25, 2014 check the fuel filler neck, it can get stuff lodged in there and corrode (to the point of losing pressure) fuel pump secured well? could also maybe be a fuel vapor canister thing but idk much about that Link to comment Share on other sites More sharing options...
Zues Marine Posted March 25, 2014 Share Posted March 25, 2014 (i wont lie i dont really hesitate to go triple digits) this probably has something to do with it Link to comment Share on other sites More sharing options...
boattlebot Posted March 25, 2014 Author Share Posted March 25, 2014 ill check the fuel filler neck today after school whens its daylight. and its not only after i run it really hard just driving it "normal" for a few miles will make me smell it now. any if i can find it ill check the purge valve cus that would make some sense cus it smell like its coming from the front of the car, probly why i can smell it while actualy driving with the window down. no check engine light tho Link to comment Share on other sites More sharing options...
JJay03 Posted March 25, 2014 Share Posted March 25, 2014 With a 96 you probably have the charcoal canister under the hood. Could be coming from that or maybe one of the rubber lines going to it. Link to comment Share on other sites More sharing options...
boattlebot Posted March 25, 2014 Author Share Posted March 25, 2014 ill try to take a look tomarro if the snows not bad, if its bad im not doing anything. Link to comment Share on other sites More sharing options...
mailman Posted March 26, 2014 Share Posted March 26, 2014 i thought 96 was when the canister moved to the rear mine is in the rear Link to comment Share on other sites More sharing options...
boattlebot Posted March 26, 2014 Author Share Posted March 26, 2014 ill look on alldata, i heard a kid at school complaining of the same thing so it could be a tsb. ill find where everything evap related is located and check that out and ill confirm or deny the location of the charcoal canister Link to comment Share on other sites More sharing options...
JJay03 Posted March 27, 2014 Share Posted March 27, 2014 It was moved to the back in 98. Link to comment Share on other sites More sharing options...
Bassnectar Posted March 27, 2014 Share Posted March 27, 2014 Can you check your fuel trims any obd tool or torque app? fuel trim may show u some useful info Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
1fast4by Posted March 27, 2014 Share Posted March 27, 2014 Start simple. Check the area around your fuel filter, the rubber hoses and small clamps that hold them on for leaks or looseness. THe fuel filter is on the driver side strut tower. And a likely cause for the smell. Link to comment Share on other sites More sharing options...
boattlebot Posted March 27, 2014 Author Share Posted March 27, 2014 ill check it tomarro before i leave school. thanks. and now im hopeing its that becuase the canister is expensive and it looks fine. i was about to start thinking that the charcoal just couldent contain the vapors anymore Link to comment Share on other sites More sharing options...
twisty Posted March 28, 2014 Share Posted March 28, 2014 i accidentally leaned on the canister in my wagon, snapped one of the hose nipples right the F off. when i saw the price of a new one, i went to a pick and pull, grabbed one off of the first impreza i saw for 10 bucks and installed it. made it through emissions, i was happy. oh ya, mine is a 95 so its still under the hood. Link to comment Share on other sites More sharing options...
JJay03 Posted March 28, 2014 Share Posted March 28, 2014 I have one of those canisters out of a 97 if you find that is the issue. Link to comment Share on other sites More sharing options...
corlon Posted March 30, 2014 Share Posted March 30, 2014 I was smelling gas around my car. bottom of the fuel filter was wet, put no leaks to be seen. replaced filter and hoses going to it. no more fuel leaks. looks like the previous owner had the hoses replaced twice, so maybe a common issue. Link to comment Share on other sites More sharing options...
boattlebot Posted March 30, 2014 Author Share Posted March 30, 2014 The rains been hammerin away and havent felt like getting wet to check stuff yet but I realy hope its something simple and quick and cheap to fix. But I have noticed that the smell goes away with the heavy rain, so it could be a small fuel leak and the water washes it off while im driving so I dont notice it Link to comment Share on other sites More sharing options...
dimwittedmoose51 Posted April 2, 2014 Share Posted April 2, 2014 Don't forget the other fuel lines running to the injectors. Especially the ones shrouded by the cast metal shrouds. I found a weeping/loose clamp there on our OB last fall. YMMV DM&FS Link to comment Share on other sites More sharing options...
boattlebot Posted April 30, 2014 Author Share Posted April 30, 2014 Well that gas smell randomly went away as far as I can tell, I have no idea whats difrent exept a new cat back exuast (stock :'( unfortunately) Link to comment Share on other sites More sharing options...
