emilymariew Posted March 24, 2014 Share Posted March 24, 2014 Hey guys! I could really use some help with this if any of you have any insight. I just pulled my leggy out of storage and keeps throwing this code, P0103 (mass or volume air flow circuit high input) whenever I give it full throttle. I am assuming that it is over boosting, and I am also assuming that it is doing so because its about 20 outside and the car isn't tuned to perform at these temperatures. The weird thing is, its also stalling every time I put the car into neutral. It didn't start doing that until after l I cleared the code with my accessport. Would that be related? Has anyone had anything similar happen to them before? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 24, 2014 Share Posted March 24, 2014 Have you cleaned the MAF sensor? DO that and try again. Use a can of MAF cleaner. Give the sensor a short blast and let it dry for a few minutes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
