LegacyDan Posted March 22, 2014 Share Posted March 22, 2014 I was offered a uk 3.0 spec b gearbox conversion to replace my JDM 5 speed setup. I'm not sure on my current gearbox code or the one on offer, I'll find out about these. Parts I think I need: Spec b 6mt Gearbox Spec b rear diff Spec b drive shaft Spec b rear axles Spec b Gearbox cradle 6mt Shifter linkage Clutch and flywheel Everything will be coming off a 05 spec b in local scrap yard so can get all the bits I need in one go for about 1200. So just want to make sure I get all I need in one go. Do I need to swap hubs? Link to comment Share on other sites More sharing options...
Waxiboy Posted March 23, 2014 Share Posted March 23, 2014 You can use your existing hubs. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 24, 2014 Share Posted March 24, 2014 the cradle is the same u just need the mount 6spd starter Link to comment Share on other sites More sharing options...
