Unknown1329 Posted March 19, 2014 Share Posted March 19, 2014 Hello, I have a 99 Legacy GT that i recently swapped a 2.2 into after the 2.5 timing belt broke. Everything runs and drives as it should but since the swap my temp gauge is erratic jumping up and down showing overheating one second the immediately showing cold sometimes it jumps around with my tach the higher the rpms the higher the temp and down to idle it reads cold. Also along those lines my fuel gauge is doing similar. It worked perfect before the swap now it never reads full and after 10 miles of driving reads empty and keeps fluctuating. I have tried swapping out the cluster to see if that went bad, it didnt. I have checked the grounds i can find and they are all grounded properly. Any help is greatly appreciated. I want to get this all figured out as soon as i can. Thank You! Link to comment Share on other sites More sharing options...
Zues Marine Posted March 19, 2014 Share Posted March 19, 2014 did you swap a phase 2 2.2L('99+) into the car? Link to comment Share on other sites More sharing options...
BlaiddDrwg Posted March 28, 2015 Share Posted March 28, 2015 Having a similar temp gauge issue, but I didn't swap the engine, I just rebuilt it. Its been fine till tonight. Link to comment Share on other sites More sharing options...
johnegg Posted March 28, 2015 Share Posted March 28, 2015 check the wiring harness on the intake manifold, look for loose or bare wires. Link to comment Share on other sites More sharing options...
