blankdeluxe Posted March 16, 2014 Share Posted March 16, 2014 I'm trying to get my emanage blue wired into my ecu and I cant for the life of me find a proper ecu pinout for my 2.2. Just each pin and what it leads to so I can cut into it. Anyone have a PDF I can see? Sent from my LG-D800 Link to comment Share on other sites More sharing options...
Osei Posted March 16, 2014 Share Posted March 16, 2014 Go to fsm here:http://www.main.experiencetherave.com/subaru_manual_scans/ info is in the body electrical section. Too large to attach here. O. Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 16, 2014 Author Share Posted March 16, 2014 I have the FSM. I'm terrible at reading wiring diagrams and the body electrical section is just full of service procedures. I'm looking for something like this thats just straight forward and easy to read for the 2.2 http://img.tapatalk.com/d/14/03/16/yvy4yvav.jpg Sent from my LG-D800 Link to comment Share on other sites More sharing options...
johnegg Posted March 16, 2014 Share Posted March 16, 2014 the ECU pin out depends on the year you are working with. so make sure you get the right one. 95 is different from 96 - 97, is different from 98 - 99. 95 is totally different, the other 2 groups are only slightly different from each other. and probably not different in the areas you will be working. Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 16, 2014 Author Share Posted March 16, 2014 the ECU pin out depends on the year you are working with. so make sure you get the right one. 95 is different from 96 - 97, is different from 98 - 99. 95 is totally different, the other 2 groups are only slightly different from each other. and probably not different in the areas you will be working. Yeah I have been looking for the 96-97. Pretty much impossible to find. Anyone have any experience with piggy backs? Sent from my LG-D800 Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 17, 2014 Author Share Posted March 17, 2014 I went through the entire FSM wire diagram and wrote down every wire that I could find in there and where it goes. Should at least be a start for anyone with the 2.2. The 2.5 is going to be different then this. (disclaimer - I take no responsibility for you frying an ECU. Use your brain and if you get in over your head find someone more qualified to work on your car) https://drive.google.com/file/d/0B2-Jw6ripKIXcm96dlQwcnM2Yzg/edit?usp=sharing Link to comment Share on other sites More sharing options...
