Ice Wagon Posted March 15, 2014 Share Posted March 15, 2014 Was about to go run errands in the subaru, let it warm up up, got about 100ft and it popped out of 3rd and now it wont go into any gear, it has never popped out of 3rd before but it recently started popping out of 4th as well as reverse. When I push the clutch pedal all the way in there is a noise from the trans and there was never any clutch smell. Help? Its the DD '96 Legacy Outback Wagon 2.2 5MT Anyone around ND have a cable 5MT with 4.11 Final Drive??? http://i415.photobucket.com/albums/pp237/Zeekery2233/20140224_154804.jpg Link to comment Share on other sites More sharing options...
jbbrjw2005 Posted March 25, 2014 Share Posted March 25, 2014 sounds like your clutch disk broke. I had that happen to me. whey aren't hard to replace just pull the engine it is easer. if you gave any questions send me an email. I can try to help you. my email is jbbrjw2005@yahoo.com Link to comment Share on other sites More sharing options...
spooln30 Posted March 28, 2014 Share Posted March 28, 2014 Well those tires don't help. Usually when it pops out of gear means you have something broken inside the trans. I don't believe the clutch is the problem, it's internal. I have seen this many times before. Link to comment Share on other sites More sharing options...
Ice Wagon Posted April 9, 2014 Author Share Posted April 9, 2014 well jbbrjw2005 wins this one http://i415.photobucket.com/albums/pp237/Zeekery2233/Mobile%20Uploads/20140409_000416.jpg Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2014 Share Posted April 9, 2014 yeah id say you broke something alright Link to comment Share on other sites More sharing options...
Stevo F Posted April 9, 2014 Share Posted April 9, 2014 Ouch!!Hopefully means your tranny is OK Link to comment Share on other sites More sharing options...
Ice Wagon Posted April 10, 2014 Author Share Posted April 10, 2014 Yea I hope so Link to comment Share on other sites More sharing options...
twisty Posted April 10, 2014 Share Posted April 10, 2014 jb weld and some light sanding, it will be fine! Link to comment Share on other sites More sharing options...
jbbrjw2005 Posted April 11, 2014 Share Posted April 11, 2014 that is easy fix. the aftermarket clutches are a little thicker then than oem. how did you get those tires to fit that thing? Link to comment Share on other sites More sharing options...
Ice Wagon Posted April 12, 2014 Author Share Posted April 12, 2014 That was a stage 1 clutch I put in 1/14/14 rated for 220hp and the ej22e is stock, the PO did it with 3" ghetto spacers above the struts. I just ordered a stage 2 clutch disc and a shifter knuckle that I'm not 100% sure will fit, Im re-using the stage 1 pressure plate as it isnt damged and I'm putting smaller tires on anyway Link to comment Share on other sites More sharing options...
