legacy gt2.5 Posted March 14, 2014 Share Posted March 14, 2014 I have an 05 legacy gt n I think my turbo is goin out...I want to up grade with out havin to tune it...is it possible or what r other options. ..all I have done is bov n intake. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted March 14, 2014 Share Posted March 14, 2014 If you don't want to tune, you can upgrade to a brand spankin new VF40/46. That is all. Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 14, 2014 Author Share Posted March 14, 2014 Its stock with a 40 I was thinkin bout the 46 ..thanx Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 14, 2014 Author Share Posted March 14, 2014 How much hp difference will I c if any Link to comment Share on other sites More sharing options...
silen7guardian Posted March 14, 2014 Share Posted March 14, 2014 I have an 05 legacy gt n I think my turbo is goin out...I want to up grade with out havin to tune it...is it possible or what r other options. ..all I have done is bov n intake. Upgrade without a tune? Not really. You can put in an OEM (VF40) turbo and not have to tune it. A VF46 (OE on newer LGTs) might spool faster than your stock VF40 though, and that will probably work fine.You could go catless with a VF40 and do a generic stage 2 ROMRaider tune, which will work but not be as good as a real tune. That will give you more power for the same turbo. Consider setting the tables so that cylinders 2 and 4 have only one degree of extra timing over cylinders 1 and 3, instead of the factory 2 degrees. You can upgrade the turbo without tuning it and drive around anyway, for science. I suggest ditching the aftermarket intake and BOV. The intake will probably just take in warmer air than the factory snorkel thing. Warmer air means less power, and maybe knock/detonation. The BOV vents air that's already been measured into the atmosphere. That means that your ECU might be putting in more fuel than you've got air for. That could mean you run rich and have poorer gas mileage. If you like the BOV, a tune could help compensate for it. Link to comment Share on other sites More sharing options...
silen7guardian Posted March 14, 2014 Share Posted March 14, 2014 http://pretuning.com/2012/06/ihi-vf40-and-vf46-turbo-comparison/ VF40 vs. VF46 Link to comment Share on other sites More sharing options...
Nrw Posted March 14, 2014 Share Posted March 14, 2014 No tune, get another VF40. Anything else will need a tune. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2014 Share Posted March 14, 2014 BTW, you don't want the car on the OEM tune any way's, its really not that good for the valves. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 14, 2014 Author Share Posted March 14, 2014 Wat if I get the 40 rebuilt... n just tune it Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2014 Share Posted March 14, 2014 A rebuilt vf40 would be fine. and stay stock, Most of us know about the problems with the factory tune or MAP. So if your going to have the car Tuned anyway's, get a vf52 and have a little more HP on stock fueling, vf52 is a direct bolt on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 14, 2014 Author Share Posted March 14, 2014 What r the prob wit stock tune m shit Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 14, 2014 Author Share Posted March 14, 2014 I dont need anythinh else except the 52 n tune? Right Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2014 Share Posted March 14, 2014 There's a timing flaw that causes burnt valves. Long story but its there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
idiot4hire Posted March 14, 2014 Share Posted March 14, 2014 Your on the right track by asking questions before you buy, but can you please spell out your words. Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 15, 2014 Author Share Posted March 15, 2014 Ok im leanin toward the vf46 or vf52 n a new oil return line. Link to comment Share on other sites More sharing options...
