Rudeboy47 Posted March 14, 2014 Share Posted March 14, 2014 So my car failed to start up this morning. Charged up the batt and started diagnosing. Batt is good so is the alternator. Let the car sit for a bit after battery has been completely charged, and when I came back to start it no dice. I noticed my parking lights stay on even when the key is disengaged. Could it be my light combo switch or possibly a bad relay? What do you guys think? Link to comment Share on other sites More sharing options...
johnegg Posted March 14, 2014 Share Posted March 14, 2014 a virgin no more. it happens to everyone sooner or later. turn off the virgin switch on top of the steering column. since all the outside lights go off when you turn off the key, it turns on the parking lights. Link to comment Share on other sites More sharing options...
BigBad Posted March 14, 2014 Share Posted March 14, 2014 There is a parking light switch on top of the steering column. If you accidentally hit it your parking lights stay on. As far as the starting issue you could check all your grounds connections. Link to comment Share on other sites More sharing options...
Rudeboy47 Posted March 14, 2014 Author Share Posted March 14, 2014 a virgin no more. it happens to everyone sooner or later. turn off the virgin switch on top of the steering column. since all the outside lights go off when you turn off the key, it turns on the parking Fml -__________________- I actually have had my encounter with that switch before. Just didn't even stop to think about that switch at all. Thanks for the legacy refreshment. Link to comment Share on other sites More sharing options...
