mbm Posted March 13, 2014 Share Posted March 13, 2014 Hi all, I looked today at a 2005 Legacy, which I am thinking of buying. One of the issues I noticed with it is that both trunk and gas door releases need to be pushed back in place before either the trunk or the gas door can be closed. It feels like a spring is missing but at the same time very stiff, i.e. pushing them back in place requires much more effort than I would expect if it was just a missing spring. What can it be? Thanks. Link to comment Share on other sites More sharing options...
13fido13 Posted March 15, 2014 Share Posted March 15, 2014 Probably sticky cables. You may have to replace them. Link to comment Share on other sites More sharing options...
mbm Posted March 16, 2014 Author Share Posted March 16, 2014 Probably sticky cables. You may have to replace them. Why would both cables become sticky at the same time? Link to comment Share on other sites More sharing options...
13fido13 Posted March 16, 2014 Share Posted March 16, 2014 Lots of potential reasons, probably dirt and crap getting into them by the drivers feet. Could be rubbed out somewhere too but that's pretty doubtful. You don't know how the vehicle was kept before you started looking at it. Salt/dirt is not nice to those components. Link to comment Share on other sites More sharing options...
apexi Posted March 16, 2014 Share Posted March 16, 2014 I agree, I think corrosion from salt/dirt/water is probably the culprit. Since it happens with both cables, I think the problem is where the cables connect to the release levers. I think there might be dirt/corrosion/salt on the ends of the cables, which is preventing them from sliding back smoothly. I would start by inspecting that area, and maybe even lubricating the ends of the cable wire to see if that helps. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted March 17, 2014 Share Posted March 17, 2014 I'd wonder if the car has been dunked up to the axles. Crawl underneath and see what it looks like. If it looks neglected walk away. Link to comment Share on other sites More sharing options...
