JamiSteven Posted March 7, 2014 Share Posted March 7, 2014 Anyone have troubles with this tune before on a stock car? Ive searched and am seeing one post from a member that just reverted back to stock tune and then later went with a protune because the studder was so bad. Ive tried the Stg1 91 and 93, both are giving me serious jolting when in boost or whenever I try and give it gas... I was almost thinking my fuel pump was on its way out however I flashed back to stock and the problem is entirely gone.. Link to comment Share on other sites More sharing options...
chimera Posted March 7, 2014 Share Posted March 7, 2014 see this http://legacygt.com/forums/showthread.php/stumble-stutter-thread-182559.html for numerous other stumble/studders. post a video if you can? seems each persons interpretation of a "stumble" can be quite difference Link to comment Share on other sites More sharing options...
JamiSteven Posted March 10, 2014 Author Share Posted March 10, 2014 Thanks for the thread, ive read through it as well as the other threads backlinked into that one.. Everyone there seems to have this and cant get rid of it, mine is gone if I remove the tune, and didnt start until I flashed the Stg1 93 tune from my AP... Also to note is I have never had a CEL until I flashed this tune, and now im getting the infamous p0011 code... Pulled the banjo filters and removed the screens completely, changed the oil and filter, cleared the code... and now the code is back again. In a nutshell: Stock tune - Zero Studder Cobb Stage1 - Stutter in every gear around 2200rpm. Link to comment Share on other sites More sharing options...
chimera Posted March 10, 2014 Share Posted March 10, 2014 copy / paste from another forum... ENGINE (DIAGNOSTICS)(H4DOTC) > Diagnostic Procedure with Diagnostic Trouble Code (DTC) DTC P0011 INTAKE CAMSHAFT POSITION - TIMING OVER-ADVANCED OR SYSTEM PERFORMANCE (BANK 1) DTC DETECTING CONDITION: • Two consecutive driving cycles with fault • GENERAL DESCRIPTION http://legacygt.com/forums/ TROUBLE SYMPTOM: • Engine stalls. • Erroneous idling CAUTION: After repair or replacement of faulty parts, conduct Clear Memory Mode http://legacygt.com/forums/ and Inspection Mode http://legacygt.com/forums/. STEPCHECKYESNO1.CHECK FOR ANY OTHER DTC ON DISPLAY. Is any other DTC displayed? Inspect the relevant DTC using “List of Diagnostic Trouble Code (DTC)”. http://legacygt.com/forums/ http://legacygt.com/forums/ 2.CHECK CURRENT DATA. 1) Start the engine and let it idle. 2) Inspect the VVT advance timing and OCV duty output using Subaru Select Monitor or general scan tool. NOTE: • Subaru Select Monitor For detailed operation procedure, refer to the “READ CURRENT DATA FOR ENGINE”. http://legacygt.com/forums/ • General scan tool For detailed operation procedures, refer to the general scan tool instruction manual. Is the VVT advance timing more than approx. 0°C and the OCV duty output more than approx. 10%? Inspect the following items and repair or replace if necessary. • Engine oil (amount, contamination) • Oil pipe (clog) • Oil flow control solenoid valve (clog or contamination in oil passage, settling at spring, stuck at valve) • Intake camshaft (sludge, damage at camshaft) • Timing belt (timing mark aligning) A temporary malfunction. Conduct the following to clean the oil passage. Replace the engine oil and idle the engine for 5 minutes, then replace the oil filter and engine oil. Link to comment Share on other sites More sharing options...
chimera Posted March 10, 2014 Share Posted March 10, 2014 ...and replace with one of these kits! http://www.infamousperformance.net/servlet/the-995/IP%26T-Filtered-Turbo-Oil/Detail I wouldn't be driving the car with a continuous P0011 appearing. turbo go boom boom. Link to comment Share on other sites More sharing options...
JamiSteven Posted March 11, 2014 Author Share Posted March 11, 2014 ...and replace with one of these kits! http://www.infamousperformance.net/servlet/the-995/IP%26T-Filtered-Turbo-Oil/Detail I wouldn't be driving the car with a continuous P0011 appearing. turbo go boom boom. Thanks Chimera, wasnt aware of that aftermarket kit. My code has since gone away and hasnt come back but now im getting a p0171 which is a whole other issue. Ill be checking the OCV tonight as well.. Car is running lean in bank1, going to clean IACV and make sure my stock airbox is completely sealed as I replaced the filter when I did the oil change/MAF clean. One month in to owning this car, gotta love it.. At least they dont cost as much as my last Audi. Link to comment Share on other sites More sharing options...
stanjk3 Posted April 22, 2014 Share Posted April 22, 2014 i was thinking of buying a used AP but after reading this, now I'm not so sure. Only engine related mods I have are a lightweight crank pulley and Avo turbo inlet hose. Don't have any stumble/shudder issues, I'm at 100K miles. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
JamiSteven Posted April 22, 2014 Author Share Posted April 22, 2014 i was thinking of buying a used AP but after reading this, now I'm not so sure. Only engine related mods I have are a lightweight crank pulley and Avo turbo inlet hose. Don't have any stumble/shudder issues, I'm at 100K miles. Mine ended up being a bad MAF, it was super dirty and although I had cleaned it once, I took it out again to find more gunk. Cleaned with a Qtip and more MAF cleaner and my issue is now gone. Link to comment Share on other sites More sharing options...
