degiacobro Posted March 6, 2014 Share Posted March 6, 2014 I've done some looking around and found a few things on this. but my hood doesn't seem to shut all the way in the front, I know some people have said that it is the cold weather that does it but I can honestly say I don't really remember if when I got the car it was like that it's just a gap in the front, the rest of it seems to go down all the way. http://img.tapatalk.com/d/14/03/06/edygura5.jpg maybe it's just the latch? Help! I'm also new to this forum so I don't know if I put this in the right place or not but I figured it was an alright place to start Degiacobro666 Link to comment Share on other sites More sharing options...
idiot4hire Posted March 6, 2014 Share Posted March 6, 2014 This happened to my last legacy it just needed to be lubed Link to comment Share on other sites More sharing options...
degiacobro Posted March 6, 2014 Author Share Posted March 6, 2014 This happened to my last legacy it just needed to be lubed What part, the latch? Degiacobro666 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2014 Share Posted March 6, 2014 Has it always been like that since you've owned the car ? Lube the moving parts latch, hinges. Adjust the rubber stop/bumpers. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
degiacobro Posted March 6, 2014 Author Share Posted March 6, 2014 Not since I've owned it, I would have noticed that when I bought it. But I'm not sure when it started. I did adjust the bumpers I'll try lubing it up and hopefully that's it Degiacobro666 Link to comment Share on other sites More sharing options...
forcedinductiongt Posted March 6, 2014 Share Posted March 6, 2014 Mine looks the same...only on driver side? Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2014 Share Posted March 6, 2014 I will say it's hard to see in the photo, can you back it outside and take a day time photo ? Are you talking about the gap at the bumper or over the head light ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
degiacobro Posted March 6, 2014 Author Share Posted March 6, 2014 http://img.tapatalk.com/d/14/03/07/ymyzamug.jpg right over the bumper in front next to the grill Degiacobro666 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2014 Share Posted March 6, 2014 Ok, I'm thinking the cars been hit. The body shop did a bad job. See the gap, or lack there of at the lower corner of the grill. Did you hit a snow bank ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
degiacobro Posted March 6, 2014 Author Share Posted March 6, 2014 It was in a accident before I got it but I don't think it was like that , and I hit a curb over winter In the snow but nothing really got damaged, had to buy a new front rim Degiacobro666 Link to comment Share on other sites More sharing options...
forcedinductiongt Posted March 6, 2014 Share Posted March 6, 2014 I dont think it was an accident...my car looks the exact same, and im 99% sure it's never been in a frontal collision Link to comment Share on other sites More sharing options...
laz Posted March 6, 2014 Share Posted March 6, 2014 Take off bumper, look for beer can inside. Not kidding. --- Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2014 Share Posted March 6, 2014 did someone back into it ? Any number of things could have caused that when you had the car parked somewhere. Looks like you'll need to remove the grill and see what's next from there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
aac0036 Posted March 6, 2014 Share Posted March 6, 2014 Clearance looks off around your headlight and grille, I would take the grille off and ensure the lower margin is clipped securely into the bumper and recheck everything else. I know that I when I had my new bumper off and then put it back everything didn't line up perfectly, particularly under the headlights. Link to comment Share on other sites More sharing options...
degiacobro Posted March 6, 2014 Author Share Posted March 6, 2014 I had some one help me with my hids so I'm guessing that was prob when it got messed up we took the grill out, that would make sense! I'm gonna try that this weekend when I have some free time Degiacobro666 Link to comment Share on other sites More sharing options...
degiacobro Posted March 25, 2014 Author Share Posted March 25, 2014 Update some of the grill clips are broken that's why it didn't sit right Degiacobro666 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 25, 2014 Share Posted March 25, 2014 Sounds like a easy fix. good for you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
degiacobro Posted March 26, 2014 Author Share Posted March 26, 2014 Does anyone know where to get oem grille clips for cheap? Degiacobro666 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 27, 2014 Share Posted March 27, 2014 NAPA or one of the dealer vendors in the Vendor Forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nrw Posted March 27, 2014 Share Posted March 27, 2014 Does anyone know where to get oem grille clips for cheap? Degiacobro666 This company should start giving me commission http://legacygt.com/forums/showpost.php?p=4773920&postcount=6 Link to comment Share on other sites More sharing options...
