rob-2 Posted May 6, 2014 Share Posted May 6, 2014 I'm wondering if you have an off valve failing to close properly Link to comment Share on other sites More sharing options...
nick916 Posted May 6, 2014 Author Share Posted May 6, 2014 I'm wondering if you have an off valve failing to close properly hope not! I'm hoping the fact my car put down those numbers with only a few bolt-ons is sign of a healthy motor... Link to comment Share on other sites More sharing options...
rob-2 Posted May 6, 2014 Share Posted May 6, 2014 hope not! I'm hoping the fact my car put down those numbers with only a few bolt-ons is sign of a healthy motor... Friend of mine has raced on a burnt valve. The power drop might not be as much as you think. Link to comment Share on other sites More sharing options...
nick916 Posted May 6, 2014 Author Share Posted May 6, 2014 Friend of mine has raced on a burnt valve. The power drop might not be as much as you think. Could there be carbon buildup on the valve causing it not to close all the way? I've seafoamed the car twice... Link to comment Share on other sites More sharing options...
rob-2 Posted May 6, 2014 Share Posted May 6, 2014 Could there be carbon buildup on the valve causing it not to close all the way? I've seafoamed the car twice... Could be a lot of things. Hard to know without measuring. Link to comment Share on other sites More sharing options...
PtPixel Posted May 6, 2014 Share Posted May 6, 2014 I'm wondering if you have an off valve failing to close properly Compression test would show this would it not? First confirm, then diagnose. Link to comment Share on other sites More sharing options...
rob-2 Posted May 7, 2014 Share Posted May 7, 2014 Compression test would show this would it not? First confirm, then diagnose. Could be a lot of things. Hard to know without measuring. Link to comment Share on other sites More sharing options...
PtPixel Posted May 7, 2014 Share Posted May 7, 2014 Must've beat me by a few seconds Link to comment Share on other sites More sharing options...
