MBrennan Posted March 1, 2014 Share Posted March 1, 2014 This message appeared after I finished resealing my injectors on a 08 LGT limited 5eat. (Only had the car a couple of weeks) After doing some research, a few people found a faulty battery to be the issue. Not so in my case. I bought and installed a new battery. The original battery was unhooked for about 4 days while I resealed the injectors. I didn't feel that it was the battery but I bought a new one anyway because I wasn't sure of the age of the original. I cleaned and reattached several ground wires along the way but I intend on retracing my steps to see if I possibly left something unhooked. I did unhook and move out of the way the main harness at the RF strut tower. Ive checked that connector several times but do not see any issues with it. My symptoms are- key to the on position all of the gauges prove out as they should and the only thing I notice out of the ordinary is the temp gauge pegs itself to hot. When continuing to the start position I get a no crank no click nothing. Any help would be appreciated. So I spent most of the afternoon retracing my steps and I can not find anything disconnected. I removed all of the grounds I had previously removed, cleaned and replaced again. Fuses are good under the hood as well as under the drivers side dash area. The start fuse under the dash lights my test light when the key is in the crank position. Would the immobilizer cause such a problem? Im not sure how Subaru is but I always had vehicles with an immobilizer issue that would at least crank over. Link to comment Share on other sites More sharing options...
oldskoolbiker Posted March 3, 2014 Share Posted March 3, 2014 i got this message when my accessport crapped out in the middle of flashing a new map. So i think that message comes up when your ecu is in a wacky state. Link to comment Share on other sites More sharing options...
MBrennan Posted March 6, 2014 Author Share Posted March 6, 2014 The message went away when I found and tightened a loose ground wire on the back of the drivers side injector guard Link to comment Share on other sites More sharing options...
BHanz34 Posted October 5, 2014 Share Posted October 5, 2014 I just put new injectors in and this is happening to me too. Where exactly is this ground you found?! Link to comment Share on other sites More sharing options...
BHanz34 Posted October 5, 2014 Share Posted October 5, 2014 It's not the one that is on the TGV, right? Link to comment Share on other sites More sharing options...
