Kodybarbera Posted February 26, 2014 Share Posted February 26, 2014 There's probably a post about this but I cannot find the exact part number for the banjo bolt and filter. I've found two. 14445AA090 & 15194AA110. Which one is it? I would really like to get one ordered so I can replace mine to make me feel better. Also what is the part number for the copper washer?? Thanks! Link to comment Share on other sites More sharing options...
JJr Posted February 26, 2014 Share Posted February 26, 2014 Here you go there are actually 2 bolt's, search Google with legacygt added 1st, then try our search function. http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-62371.html Link to comment Share on other sites More sharing options...
Kodybarbera Posted February 26, 2014 Author Share Posted February 26, 2014 That still doesn't give me the part number Link to comment Share on other sites More sharing options...
JJr Posted February 26, 2014 Share Posted February 26, 2014 This http://legacygt.com/forums/showthread.php/banjo-bolt-part-176866.html?p=3686343 then http://opposedforces.com/parts/info/15194AA110/ Just do a bit of searching. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2014 Share Posted February 26, 2014 You don't need to replace the bolts, just remove the filters, install new crush washers. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nubie Posted February 26, 2014 Share Posted February 26, 2014 I always order the 14445AA090 Link to comment Share on other sites More sharing options...
