emc2003 Posted February 25, 2014 Share Posted February 25, 2014 I purchased an 06 LGT a few months back and noticed the clock/economy gauge did not work. Long story short I pulled the center bezel out and found this. It looks like it may have been switched from nav to the clock assembly before it was sold. Obviously they kept the nav and they were not concerned with hooking the clock back up. What is the best plan of action as far as reconnecting the clock? Is there an adapter kit out there so I do not have to cut the wiring? This is the back of the gauge, I'm having issues uploading the other image. Any assistance is greatly appreciated. Any wisdom/experience out there? Do the plugs in the second photo look like aftermarket gauges, nav or did they replace with a different year clock? Thanks, Dan Link to comment Share on other sites More sharing options...
emc2003 Posted February 25, 2014 Author Share Posted February 25, 2014 Here are the connections from the car. Link to comment Share on other sites More sharing options...
emc2003 Posted February 25, 2014 Author Share Posted February 25, 2014 Any ideas? I know if there is an answer it will come from here. Link to comment Share on other sites More sharing options...
emc2003 Posted April 1, 2014 Author Share Posted April 1, 2014 Do I need a different clock/gauge all together? Link to comment Share on other sites More sharing options...
08spec Posted April 5, 2014 Share Posted April 5, 2014 I wish I knew. Bump, someone heeeelp! Link to comment Share on other sites More sharing options...
thesavo Posted April 5, 2014 Share Posted April 5, 2014 What's the front look like? That middle bit looks like a hole was drilled to run a wire harness. Link to comment Share on other sites More sharing options...
emc2003 Posted April 5, 2014 Author Share Posted April 5, 2014 The person before me wired an aftermarket aux plug. Thanks for the response. Dan Link to comment Share on other sites More sharing options...
emc2003 Posted May 7, 2014 Author Share Posted May 7, 2014 Anyone have an answer? Can I just run wires from the car to the clock and skip the plugs? I have searched everywhere and I am coming up empty. Do you think the owner before me had the nav system and just put the cubby and economy/clock to fill the empty spot. Thanks beforehand for any wisdom on this. Dan Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2014 Share Posted May 7, 2014 Have you asked this in the interior forum below ? Do you have the service manual, that may help ? http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
emc2003 Posted June 22, 2014 Author Share Posted June 22, 2014 I'm going to make another attempt at repairing. I have searched this to no end since the purchase of the vehicle. I have contacted the dealer to no avail. Any info is greatly appreciated. Dan Link to comment Share on other sites More sharing options...
firehawk618 Posted June 22, 2014 Share Posted June 22, 2014 Best bet is look at the wiring schematics for both setups. Get the right plug for your clock and tap into the appropriate wires. I'm certain the wires you need will all be there. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
emc2003 Posted June 22, 2014 Author Share Posted June 22, 2014 Is anyone familiar with the plugs in the second picture? One has 16 pins the other 20. D Link to comment Share on other sites More sharing options...
firehawk618 Posted June 23, 2014 Share Posted June 23, 2014 Schematics my friend. If you do not have them then get them. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
thesavo Posted June 24, 2014 Share Posted June 24, 2014 Sometimes, someone just needs to be lead to the river, then forced a drink. By the looks of "vacation pics" from "my" 2005 and 2008 US DM Tour, you want connector i59. It's a 10 pin connector. You have a 2006. I'll post excerpts from both, they should apply to yours. Also note that it will seen the airbag or SRS is involved. Sent from my DROID RAZR HD using Tapatalk Link to comment Share on other sites More sharing options...
heiche Posted June 24, 2014 Share Posted June 24, 2014 Looking at your first pic, see the empty black plug on the clock module? I believe if the car came with a Nav setup, then you don't have the plug for that. It would appear as though others have tried to wire it up themselves. Here's a thread I just found that has some info. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
emc2003 Posted June 25, 2014 Author Share Posted June 25, 2014 That's what I was thinking. Thank you for the assistance. Dan Link to comment Share on other sites More sharing options...
emc2003 Posted June 25, 2014 Author Share Posted June 25, 2014 I did see that thread, although I wasn't sure it purtained to me. As I dug further into the dash I found all plugs for navi. So obviously I need to rewire a new plug for both the clock and the light in the cubby. Thank you all for the help thus far. Dan Link to comment Share on other sites More sharing options...
emc2003 Posted June 26, 2014 Author Share Posted June 26, 2014 Just got off the horn with a local Subaru dealership and the car came with factory nav. The previous owner removed it and plugged the hole with the optional bezel and clock/Econ gauge. Now I need to find the 10 pin male plug and the 20 pin female. Dan Link to comment Share on other sites More sharing options...
scontivt Posted June 26, 2014 Share Posted June 26, 2014 Or... you could install a nav unit :-)... lol Link to comment Share on other sites More sharing options...
emc2003 Posted June 26, 2014 Author Share Posted June 26, 2014 That is an option. I would rather spend on performance upgrades. Dan Link to comment Share on other sites More sharing options...
