mbciuso Posted February 23, 2014 Share Posted February 23, 2014 Hi, tried to replace the light bulb in one of the license plate lights. I had assumed the lens was held in place by a screw, but that's not the case. I tried to figure out how to access he bulb and have had no luck. Any thoughts on his? Thanks, Link to comment Share on other sites More sharing options...
kred Posted February 23, 2014 Share Posted February 23, 2014 You want to get to it from the back by twisting the plastic housing for the bulb counterclockwise I think. Then the wire, housing, and bulb can be pulled out together. Link to comment Share on other sites More sharing options...
Drift Motion Posted February 23, 2014 Share Posted February 23, 2014 take out the carpet/lining from inside the trunk, and you can reach from there very tricky design and VERY easy to lose the bulb inside Link to comment Share on other sites More sharing options...
apexi Posted February 23, 2014 Share Posted February 23, 2014 You remove them from inside the trunk area. I forget if have to remove the whole trunk mat/trim piece, or if you can just remove some of the trim clips and reach your hand in there and twist the bulb socket out. The pictures/links should give you a general idea though. http://legacygt.com/forums/showpost.php?p=2667925&postcount=6 http://legacygt.com/forums/showthread.php/license-plate-bulb-removal-replacement-33919.html Link to comment Share on other sites More sharing options...
Theheatfan33 Posted February 23, 2014 Share Posted February 23, 2014 I suggest having some sort of magnet around just in case you drop the bulb inside, so you can easily get it back out. At least it worked for me when I dropped an led bulb in there, not sure if a regular would work though. Link to comment Share on other sites More sharing options...
codger2 Posted December 15, 2017 Share Posted December 15, 2017 ...the bulb doesn't want to come out of the socket. It's easy enough from the outside on a wagon to unscrew the plastic lens, then pull the housing out and access the bulb. But it doesn't pop out of the socket by just pulling it straight out. a gentle twist doesn't work either. it wiggles a bit laterally, and in and out also, so I don't think it is seized with age.I don't want to shatter it by forcing it. anybody know how to unplug the bulb itself? Link to comment Share on other sites More sharing options...
Wasted Potential Posted December 15, 2017 Share Posted December 15, 2017 Snap the bulb and pull out rest of glass and filament with pliers. If it doesn't come out with pliers and a probing screw driver, it's shot so bad you need to solder in a new socket. Link to comment Share on other sites More sharing options...
codger2 Posted December 16, 2017 Share Posted December 16, 2017 Snap the bulb and pull out rest of glass and filament with pliers. If it doesn't come out with pliers and a probing screw driver, it's shot so bad you need to solder in a new socket. I may end up doing that. The search didn't give a clear answer, but leant toward twist it counterclockwise rather than just pull straight out. It doesn't come out with counterclockwise rotation while pulling, or with pushing. Link to comment Share on other sites More sharing options...
Wasted Potential Posted December 16, 2017 Share Posted December 16, 2017 I cannot recall if the bulb is a 194 looking thing or 921, but those pull straight out. Then again, the socket replscement is only like $20 i think if you have to solder new one in there. Can't tell you how many times I have had to pop the bulbs to get mine out of other cars. If they don't come out, they're usually burnt in there haha. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 16, 2017 Share Posted December 16, 2017 I have to replace mine too.. I've seen other cars on the road with the flickering cheap LED's mine fell victim as well.. it was pretty funny looked like a light show until I taped the rear trunk and it stopped.. I think I had 168's in but I picked up some 192's I found the 5 LED one I had I found was a little too bright. Link to comment Share on other sites More sharing options...
n888aw Posted January 8, 2018 Share Posted January 8, 2018 So i recently stripped two of the screws for my license plate lights. Would a screw extractor work in this case? All the reviews of ones that i have found say they snapped off. Ideas? Link to comment Share on other sites More sharing options...
