forcedinductiongt Posted February 20, 2014 Share Posted February 20, 2014 My 2006 5eat is already stage two, and I'll be installing a six star speed refurbished vf52 and walbro 255 within the next week. Is this safe to drive to the tuner (efi logics)? It's about 50 miles highway, I figured it would be fine as long as I don't romp on it Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Nrw Posted February 20, 2014 Share Posted February 20, 2014 Loop the wastegate. Doing that will cause you to only make a max of about 7psi. Other than that should be fine on stock injectors and not romping on it. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 20, 2014 Author Share Posted February 20, 2014 Loop the wastegate. Doing that will cause you to only make a max of about 7psi. Other than that should be fine on stock injectors and not romping on it. I understand the concept, but how does one go about looping a vf52? Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Nrw Posted February 20, 2014 Share Posted February 20, 2014 I understand the concept, but how does one go about looping a vf52? Sent from my SPH-L720 using Tapatalk Connect a hose from the reference port on the turbo straight to the wastegate. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 20, 2014 Author Share Posted February 20, 2014 Connect a hose from the reference port on the turbo straight to the wastegate. Thanks! Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
kongzilla Posted February 20, 2014 Share Posted February 20, 2014 Stay out of high boost and you should be fine. Link to comment Share on other sites More sharing options...
Industry Posted February 21, 2014 Share Posted February 21, 2014 Not to hijack, but I have sort of the same question. I need to drive a bit further, and my car is on the stock tune. It's getting a vf52 and catless downpipe. The other wrench in the mix is that it's a fresh rebuild. Any advice? Link to comment Share on other sites More sharing options...
ragman Posted February 21, 2014 Share Posted February 21, 2014 If you have an accessport or the cables for opensource; most all tuners can give you a basemap to load to get you to them safely. Link to comment Share on other sites More sharing options...
Industry Posted February 21, 2014 Share Posted February 21, 2014 I do have a tactrix 2.0 Link to comment Share on other sites More sharing options...
quick4dr Posted February 21, 2014 Share Posted February 21, 2014 Give Pete at EFI a shout I'm sure he could have Mikey whip up a basemap to get you there safe. (if you have a cable, or accessport) Or as others stated loop the waste gate and drive like grandma on the way to church. Link to comment Share on other sites More sharing options...
acumenhokie Posted February 26, 2014 Share Posted February 26, 2014 Whoever is tuning you should be able to send you a base map. Keep in the lower RPMs and out of boost and you should be ok. I drove 100 miles to my tuner after swapping turbo (20g), plugs, ebcs, injectors, fuel pump and more. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 27, 2014 Author Share Posted February 27, 2014 Whoever is tuning you should be able to send you a base map. Keep in the lower RPMs and out of boost and you should be ok. I drove 100 miles to my tuner after swapping turbo (20g), plugs, ebcs, injectors, fuel pump and more. I wonder if i'll even need a base map, that 20g set up is quite a bit far from the vf52 im installing hahah Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
chimera Posted March 3, 2014 Share Posted March 3, 2014 Or as others stated loop the waste gate and drive like grandma on the way to church. Clearly you haven't seen my grandma driving to church http://memecrunch.com/meme/1465X/thats-no-race-car/image.png Link to comment Share on other sites More sharing options...
Bassman81 Posted March 13, 2014 Share Posted March 13, 2014 Forced Induction, How did your VF52 look like from SixStarSpeed. Sorry to hijack the thread, but I'm interested in the VF52 swap myself. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted March 13, 2014 Author Share Posted March 13, 2014 Forced Induction, How did your VF52 look like from SixStarSpeed. Sorry to hijack the thread, but I'm interested in the VF52 swap myself. It looked great, came with braided steel oil lines...almost brand new Link to comment Share on other sites More sharing options...
Bassman81 Posted March 20, 2014 Share Posted March 20, 2014 Thanks for answering that question. I'll be doing it soon! Link to comment Share on other sites More sharing options...
