outback_wagon805 Posted February 17, 2014 Share Posted February 17, 2014 for some reason my car only revs to 4k and will not go past that, it sputters, and if i rev it to 4k and let ff the gas petal it just dies and starts right back up. i checked timing belt and it was ok, i thought it might have jumped a tooth or something but all is fine, after that i compression checked all cylinders and it all checked out fine. I'm just hoping it has nothing to do with the head gasket, its the original and i have 230,000 on the car and original clutch. any ideas or has anyone else gone thought this? Link to comment Share on other sites More sharing options...
snederhiser Posted February 18, 2014 Share Posted February 18, 2014 Hello; I would check the fuel pump with a pressure gauge. Then pull the pump and check the filter sock, then the underhood filter. Your pump should put out 36psi and 60psi with the return line pinched, Steven. Link to comment Share on other sites More sharing options...
Nubie Posted February 18, 2014 Share Posted February 18, 2014 Any codes? If it's only reving to 4000k that usually means it's in limp mode. Check the codes, my little bothers ended up being a transmission speed sensor that was causing his issue. Link to comment Share on other sites More sharing options...
outback_wagon805 Posted February 18, 2014 Author Share Posted February 18, 2014 I changed the fuel pump 2 months ago. The pressure is good also. Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
outback_wagon805 Posted February 18, 2014 Author Share Posted February 18, 2014 At nubie, is the speed sensor the same for an auto trans and a m/t Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted February 18, 2014 Share Posted February 18, 2014 At nubie, is the speed sensor the same for an auto trans and a m/t the first thing I thought too was that it sounded like limp mode.. the sensors have different part numbers but im running an AT one in my MT and have no problems Link to comment Share on other sites More sharing options...
Nubie Posted February 18, 2014 Share Posted February 18, 2014 Zeus thank you, that answers that question. But i would difinitely get the codes at least so you can start looking for the problem. I would not look into the speed sensor until you know what codes are there. Link to comment Share on other sites More sharing options...
