speedfreek Posted February 15, 2014 Share Posted February 15, 2014 I have an 2006 LGT with a toasted engine. What years of which turbo Subarus are interchangeable? Link to comment Share on other sites More sharing options...
MrTris Posted February 15, 2014 Share Posted February 15, 2014 Short answer -- All of them. We're a bit like Legos, in that respect. You've got a couple of options here -- both are expensive, so just prepare yourself for that right now. Your bottom line to get back on the road with this car is at least 4k, and realistically, about 5+, depending on how crazy you wanna go. If there's no possible way you can make this happen right now, just stop reading and call a scrap yard because you've got a very pretty, very broken, very expensive paperweight. What happened? How bad is the damage? If you want a quick, back-to-stock solution, we'll recommend snagging an EJ257 from the dealership, or from one of the many vendors here. That'll run you two large. It'll bolt right up to your intake manifold and off you go. For a bit more, you can start thinking about forged internals -- pistons, rods, etc, which will give you much better performance over stock, but again, this is where it not only gets expensive, but also requires a bit of a commitment to further customization of the car as you start to piece it back together. What are your plans for the car? Are you in love with it and want to keep it, or is it just a nice ride for you? (you're here, so I'm guessing it's the former) Take a look around in the sub forums and read some of the build threads -- Anyone who's got a heavily modded car started out exactly where you're at now, and it'll give you a good idea of what kind of journey you're about to embark upon. Link to comment Share on other sites More sharing options...
speedfreek Posted February 15, 2014 Author Share Posted February 15, 2014 I had a broken ring land on#4 piston.Put new pistons in and for some reason lost oil pressure after 200 miles. rods shot as are all bearing surfaces including cams. Link to comment Share on other sites More sharing options...
hobo2701 Posted February 15, 2014 Share Posted February 15, 2014 most people just get a ej257 which is the sti block or have there block halves machined and upgrade to forged pistons. the blown ringland on cylinder 4 is all too common and its a lot to do with the way the factory tune is under high boost cylinder 4 gets less fuel and runs lean and kaboom knock and blown piston.. so i would upgrade pistons and get a good tune from a knowledgable subaru person. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 15, 2014 Share Posted February 15, 2014 See my click here link for the right way to do it for a realible DD'er. It really is that easy. Over 30,000 miles at 21psi, runs great, gets good mpg. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted February 16, 2014 Share Posted February 16, 2014 Here's a great start, and doing business with a Fellow LGT.com member: http://legacygt.com/forums/showthread.php/fl-rebuilt-2009-ej255-longblock-fresh-219913.html And also this one, all hopped up: http://legacygt.com/forums/showthread.php/ia-built-sleeved-o-ringed-short-block-220562.html Link to comment Share on other sites More sharing options...
speedfreek Posted February 16, 2014 Author Share Posted February 16, 2014 I need a rebuilder engine for the shop to build Link to comment Share on other sites More sharing options...
speedfreek Posted February 21, 2014 Author Share Posted February 21, 2014 It is my understanding that the heads changed for some years Link to comment Share on other sites More sharing options...
HappySub Posted February 22, 2014 Share Posted February 22, 2014 Can't you take the block to a local machine shop and have the blocked cleaned up and worked a little bit? Then get new parts from the local race shop? Doesnt someone make aluminum pistons, rods and the think the heads are already aluminum. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 22, 2014 Share Posted February 22, 2014 You don't want to be changing heads without other issues. Heuberger a Vendor here has a ej257 for $1645. Get the gasket set for your year car, have your heads rebuilt with that gasket kit and go from there. Order a ej257 from a 2011 STI. Read my click here link. Contact my Tuner for your tuning needs, www.tuningalliance.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
