Milsparro Posted February 11, 2014 Share Posted February 11, 2014 Can the 2005 oil pickup 15050AA050 be used in place of the 2006 oil pickup 15049AA110 in a 2006 Legacy 2.5i (NA, SOHC)? Link to comment Share on other sites More sharing options...
Milsparro Posted February 11, 2014 Author Share Posted February 11, 2014 (Dealer took over a week to get me the wrong one) Link to comment Share on other sites More sharing options...
Danteneon Posted February 11, 2014 Share Posted February 11, 2014 While those part numbers have no interchangeability with each other, I wouldn't know if there is some pan design difference that would keep you from using the different part. Based on what I know about Subaru's numbering system, I would say they are not interchangeable. Maybe someone else has tried this? I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2014 Share Posted February 11, 2014 Well, some of the 2005-2006 Legacy GT's had oil pick tubes that cracked and caused a engine failure. Why would you want one of them ? Most of the guy's have gone with a the Killer B oil pick up or some other after market one. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted February 11, 2014 Share Posted February 11, 2014 Killer b or motor rebuild. You pick! Link to comment Share on other sites More sharing options...
Milsparro Posted February 11, 2014 Author Share Posted February 11, 2014 Well, some of the 2005-2006 Legacy GT's had oil pick tubes that cracked and caused a engine failure. Why would you want one of them ? Most of the guy's have gone with a the Killer B oil pick up or some other after market one. Because I had an oil pickup tube crack, this was the replacement... and I want rid of this particular car before the engine rebuild, so I'm not going to invest more than I have to. My route to work changed when I moved, need more ground clearance/weight for the drifts. Link to comment Share on other sites More sharing options...
Milsparro Posted February 11, 2014 Author Share Posted February 11, 2014 Ok, so I called my dealer, the parts guy checked with the mechanics, he said they said the oil pan changed at the same time the pickup changed, so the pickups aren't interchangeable. Link to comment Share on other sites More sharing options...
