Pavoni8297 Posted February 9, 2014 Share Posted February 9, 2014 Hey, I have an 08 spec b and its got the 6 speed. I have only driven 5 speeds and less three on the tree . When I am in sixth and down shifting it pops out of 6th and wants 4th... I would think 5th.... Link to comment Share on other sites More sharing options...
pm2009gtspecb Posted February 9, 2014 Share Posted February 9, 2014 I'm not sure off of the top of my head if there is a difference in gear ratios between the '08 and the '09, but in my '09, down-shifting from 6th to 5th does very little in most situations and is really only helpful when trying to slightly increase acceleration around 40 mph. It will really depend on the situation that you are in and why you need to down-shift. From 6th to 4th is not an issue at 45-55 mph, but if you are going 70 mph or above, the change in RPM could be extreme. If you are slowing down your brakes will take on some of the job of slowing the car, and skipping multiple gears depends on how aggressively you use the brakes. Link to comment Share on other sites More sharing options...
rob-2 Posted February 9, 2014 Share Posted February 9, 2014 Cup the shifter and guide it from 6th to 5th by scraping it along the right side of the gear box. Otherwise if you're talking about something else it's not clear in your post. Link to comment Share on other sites More sharing options...
Pavoni8297 Posted February 9, 2014 Author Share Posted February 9, 2014 that's what I was talking about, I am doing that and do that for the 5 to sixth shift....just curious if others noticed that..... just getting comfortable with the gearbox... Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2014 Share Posted February 9, 2014 I don't understand, popping out of 6th and wants to go into 4th ? The tranny can't do that by itself. I find that if I don't hold the shifter to the right when going from 5th to 6th, sometimes I catch myself putting it back in 4th. Down shifting I don't have any problems. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
