csteere Posted February 4, 2014 Share Posted February 4, 2014 I'm having my clutch replaced tomorrow and I didn't get a new flywheel because the mechanic told me I wouldn't need one if all I'm doing is using it as a daily driver and only going WOT every once and a while. (is this true) Link to comment Share on other sites More sharing options...
idiot4hire Posted February 4, 2014 Share Posted February 4, 2014 Unless he's ordering you a direct oem replacement and your fly wheel is okay. He may have done subarus in the past with single mass flywheels and assumed they are all the same. Your lgt is a duel mass that can't be resurfaced. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 I guess he's trying to save you money. Any sane person would not put a new clutch set up on a old FW. Ask him to grease the starter shaft while its out. the gear tends to hang up on them in cold weather. Make sure he also greases the tranny snout where the TOB slides. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
