forcedinductiongt Posted February 3, 2014 Share Posted February 3, 2014 Just replaced my radiator, only to discover my cooling fans were inoperable. Thought it was a relay, but when I put the car in test mode they fired right up. I burped the hell out of the system, could it be a fault in the cooling fan temp sensor? Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
boostgt2 Posted February 3, 2014 Share Posted February 3, 2014 wow man I am having the opposite problem my fans kick on to early I think. Just replaced my thermostat and the fans kick on before it opens!!! Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 3, 2014 Author Share Posted February 3, 2014 I replaced my thermostat.... and they don't turn on at all! I don't suppose you bought your lgt in austrailia... everything is upside down down there Link to comment Share on other sites More sharing options...
boostgt2 Posted February 3, 2014 Share Posted February 3, 2014 Forcedinductiongt if your fans are not kicking on after a thermostat change I would think its working as normal as long as the car is not overheating. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 3, 2014 Author Share Posted February 3, 2014 Ive let it get to 192....still not kicking in Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
boostgt2 Posted February 4, 2014 Share Posted February 4, 2014 Do you know what temp the fans are supposed to kick on? Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 4, 2014 Author Share Posted February 4, 2014 No, but I'm assuming before 192 Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
SpecBFan Posted February 4, 2014 Share Posted February 4, 2014 I just did a new radiator/fan setup and my fans come on at about 196°. Yours might be running fine. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 4, 2014 Author Share Posted February 4, 2014 What's considered overheating in our cars? About 205? Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 http://people.csail.mit.edu/ilh/vacation/ You may find the info in there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
forcedinductiongt Posted February 4, 2014 Author Share Posted February 4, 2014 http://people.csail.mit.edu/ilh/vacation/ You may find the info in there. 205, it says... thanks a lot! Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
