blackturbo Posted February 2, 2014 Share Posted February 2, 2014 Hi all, I have a suburu legacy wagon GT with the 4 cylinder, dont know wat motor. its got 80k on it. i get no heat most the time, it blows air and all. the only time i get heat, the temp gauge will goto full hot (doesnt appear to overheat) then i get some heat, and the temp gauge will either stay at Hot for awhile, or go down to normal. sometimes it will stop giving heat when it goes down to normal. maybe a malfunctioning thermostate or heater control valve? i dont wanna just throw money in buying a bunch of parts if the part is not broken. thanks all! I might keep the car and see if i cant make it higher cause i live on a farm and it goes off road sometimes. also the four wheel drive is horrible, it seems limited slip on each axle. it never appears to get all 4 wheels spinning at the same time in the mud. but seems like an OK car. thanks! Mark Link to comment Share on other sites More sharing options...
Headtrauma89 Posted February 2, 2014 Share Posted February 2, 2014 The temp gage going to "full hot" means its overheating... Link to comment Share on other sites More sharing options...
Zues Marine Posted February 3, 2014 Share Posted February 3, 2014 Check your coolant level. Link to comment Share on other sites More sharing options...
spooln30 Posted February 3, 2014 Share Posted February 3, 2014 You Sir are now a member of the 2.5 Headgasket Club. Lol. All the way into the red and you don't think it's appears to be overheating? Really? It shouldn't go past the half way point on the gauge and mine will stay lower than the half mark. Link to comment Share on other sites More sharing options...
vr4 Posted February 3, 2014 Share Posted February 3, 2014 Yup. Very low on coolant and blown headgaskets Link to comment Share on other sites More sharing options...
blackturbo Posted February 3, 2014 Author Share Posted February 3, 2014 ok thank you,there is no coolant in there but i had to drive it this morning and it was on full H all the way, bought some coolant and returned home, waiting for it too cool down so I can add it. I dont think theres any damage done, as its very cold here where I live. well thats what iam hoping, it was driving ok,running good. Link to comment Share on other sites More sharing options...
Zues Marine Posted February 3, 2014 Share Posted February 3, 2014 dont forget to bleed the air from the lines as you add the coolant Link to comment Share on other sites More sharing options...
Headtrauma89 Posted February 4, 2014 Share Posted February 4, 2014 It is highly unlikely that there is no damage done. By over heating the heads, they will warp Link to comment Share on other sites More sharing options...
blackturbo Posted February 4, 2014 Author Share Posted February 4, 2014 i dont think there was damage, its very cold here, refilled with coolant, car runs fine. did some wide open throttle tests, still pulls nice and strong, and no steam or white smoke out the exhaust. I guess ill be able to tell over the next few days if the car looses coolant. but nothing is coming out the exhaust, thats usaully the sign of a damaged head gasket on cars ive owned before. and how do i bleed air outta the cooling system? thanks guys. mark Link to comment Share on other sites More sharing options...
snederhiser Posted February 6, 2014 Share Posted February 6, 2014 Mark; Subies are a different animal. The cooling system is a reverse flow, top hose is the feed and the lower hose is the return. When the head gasket fails it allows the combustion chamber gases to build pressure in the cooling system, thus coolant is lost in the overflow bottle. So when the coolant level drops the heater quits working and drops below the feed so the engine overheats. Can be sure this is head gaskets unless the thermostat is stuck and or faulty radiator cap, Steven. Link to comment Share on other sites More sharing options...
