smithwoods Posted February 1, 2014 Share Posted February 1, 2014 My 2006 Legacy wagon (116000 miles) has a hard shift into 4th when cold (below 30). If I use the sport mode and hold it in 3th for a 1/2-1 mile it will upshift smooth. When warmed up all is ok. the car is new to me and it was warmer when I got it. Any thoughts? Thanks, Dan Link to comment Share on other sites More sharing options...
DonnyJagaru Posted February 3, 2014 Share Posted February 3, 2014 Transmission fluid flush and filter replacement? Link to comment Share on other sites More sharing options...
smithwoods Posted February 4, 2014 Author Share Posted February 4, 2014 That was the first thing I did because the fluid was dark and no record of any fluid change. It's been about 100 miles now and the 1 2 3 shifts are smoother. the shift to 4th is less hard when cold so I hope it is cleaning itself out. I will say it has to be the easiest car to do a fluid change on. A drain plug and external filter should be the standard on all cars. Link to comment Share on other sites More sharing options...
