Redryan98 Posted January 30, 2014 Share Posted January 30, 2014 I've got an 07 LGT with ~56k miles, overall in great shape. I realized recently though that my airbag system is on the fritz. The yellow lights that are on the console with the map lights are all over the place. When working normally (with no passenger) the "Pass Air Bag" and "Off" lights are lit up. Sometimes just the "Off" light is lit. Other times just the "Pass Air Bag" light is lit. Sometimes none are lit, Other times one is dim but the other is bright. At times I'll also see the red "Airbag" warning light on the dash First thing I was going to do was pull that console off and just make sure the wires are plugged in correctly. Can someone advise the best way to pull that piece off without damaging it? Any other ideas what the error could be? Thanks! Link to comment Share on other sites More sharing options...
MasAyinde Posted January 30, 2014 Share Posted January 30, 2014 Here you go, common problem: http://legacygt.com/forums/showthread.php/airbag-light-sometimes-console-problemi-149073.html?t=149073&highlight=airbag+light Link to comment Share on other sites More sharing options...
stm25rs Posted January 30, 2014 Share Posted January 30, 2014 Here you go, common problem: http://legacygt.com/forums/showthread.php/airbag-light-sometimes-console-problemi-149073.html?t=149073&highlight=airbag+light Shortcut to post #60, with pics: http://legacygt.com/forums/showpost.php?p=4278790&postcount=60 Link to comment Share on other sites More sharing options...
Redryan98 Posted January 31, 2014 Author Share Posted January 31, 2014 wow, awesome. Thanks! Link to comment Share on other sites More sharing options...
