giogio43 Posted January 28, 2014 Share Posted January 28, 2014 i have JDM 2005 subaru legacy 3.0 sedan... anyways its really obvious when i push the car to its limits, really Hot air blows out with low fan speed. Now the cliamte control and everything is OFF, and it just does it when i drive fast. help me out here, i could not find any answers here. This whole thing does not look like it is a problem caused from some damage or something, i had the car system checked it is in ideal condition no errors or so. Link to comment Share on other sites More sharing options...
rob-2 Posted January 28, 2014 Share Posted January 28, 2014 It's directly connected to the coolant temp when the system is off. Link to comment Share on other sites More sharing options...
LegacyMike Posted January 28, 2014 Share Posted January 28, 2014 Hi, I find sometimes my 08 Legacy does this when I'm on the highway for a little bit. It'll blow air even when everything is off. I've noticed this effect on some other cars I drive as well. Best I can figure (and I could be wrong) is that even though the fan is off, the passage of air through the engine bay from driving fast eventually works its way through the system into the cab. Try hitting the button that circulates the air inside the cabin (the symbol looks like a car with a horizontal u-turn arrow in it). When I did this, it fixed the problem for me. Let me know if this helps. Link to comment Share on other sites More sharing options...
Berzerklo Posted January 28, 2014 Share Posted January 28, 2014 ^^^ What that guy said. Air moves from high to low pressure. When you are driving fast, the front of the car is at a much higher air pressure than inside the cabin. If the differential pressure becomes high enough, air will flow from the outside air intake for the HVAC system into the cabin. You can close that intake with the recirc button like LegacyMike said. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 28, 2014 Share Posted January 28, 2014 When you give it more gas, the ECU shuts off the AC compressor so you have more HP. Let off the gas and the AC comes back on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boostgt2 Posted January 28, 2014 Share Posted January 28, 2014 Make sure before you turn your climate control off that you set it to recirculate air inside the car and not the outside air. Link to comment Share on other sites More sharing options...
rob-2 Posted January 28, 2014 Share Posted January 28, 2014 Make sure before you turn of your climate control off that you set it to recirculate air inside the car and not the outside air. And you can do this with the system off, but the car must be on. Link to comment Share on other sites More sharing options...
robinlsb Posted January 28, 2014 Share Posted January 28, 2014 When you give it more gas, the ECU shuts off the AC compressor so you have more HP. Let off the gas and the AC comes back on. I thought everyone knew that:lol: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
giogio43 Posted January 28, 2014 Author Share Posted January 28, 2014 its my first car, i dont know that much robin. thanks for the tip what mike and others said sounds very logical and im sure it will work. ill see tomorrow. Thanks a lot!!! Link to comment Share on other sites More sharing options...
robinlsb Posted January 28, 2014 Share Posted January 28, 2014 its my first car, i dont know that much robin. thanks for the tip what mike and others said sounds very logical and im sure it will work. ill see tomorrow. Thanks a lot!!! No problem. Read up on your car, here and other places. You will find the LGT is set up for speed;) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
nouse4aname Posted January 29, 2014 Share Posted January 29, 2014 Yep turn recirc on or turn the temp down before you turn the system off. The thermostat setting is still used even with the fan off. Link to comment Share on other sites More sharing options...
giogio43 Posted January 29, 2014 Author Share Posted January 29, 2014 so i played around with climate control while going 180kph - recirc on with the temp down it did the trick! you can still feel if you get your hand close to vents that theres a fire breathing dragon sitting deep in there somewhere but no hot air is blowing so its all cool. THANKKKSS Link to comment Share on other sites More sharing options...
