Toallhisdoom Posted January 23, 2014 Share Posted January 23, 2014 Car threw these codes the other day p0500 p1540. Speedometer does not work. CEL on. Idles low. Other wise seems fine. It is in the negative temps in ny the past week not sure if that could cause the speed sensor to freeze up? Where is the sensor located? I think the code is for speed sensor 2? Any ideas? Link to comment Share on other sites More sharing options...
Headtrauma89 Posted January 24, 2014 Share Posted January 24, 2014 The spped sensors are on the passenger side of the trans. Looks like a black cylinder. Iirc one is right behind the bell housing and the other is near the axle output. Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 24, 2014 Author Share Posted January 24, 2014 Alright thanks! Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 24, 2014 Author Share Posted January 24, 2014 Ok located the sensor... Now, what models/year cars have the same sensor? Few guys on CL that has parts cars so need something that will work. Not paying 100 for a new one. Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 24, 2014 Author Share Posted January 24, 2014 Found a guy with a 98 forester that he says i can have the sensor from for 35 bucks. He claims he looked it up and its the same. Any clue? Link to comment Share on other sites More sharing options...
Headtrauma89 Posted January 24, 2014 Share Posted January 24, 2014 i believe they changed in 99. But just be sure get on autozone.com or something, look up the part number for both vehicles and compare Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 24, 2014 Author Share Posted January 24, 2014 I went on rockauto. Its the same! Thanks for the tip! Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 24, 2014 Author Share Posted January 24, 2014 So pulled my front sensor out. When i put power to it and have my volt meter on it it seems to work. What else could cause this to read as bad? Link to comment Share on other sites More sharing options...
Headtrauma89 Posted January 25, 2014 Share Posted January 25, 2014 Check your rear sensor, if the code is for sensor 2. Less likely possibility is that the paddle wheel inside the trans Is broken. I'd replace the sensors first though Link to comment Share on other sites More sharing options...
Toallhisdoom Posted January 25, 2014 Author Share Posted January 25, 2014 Will check rear sensor tomorrow. Thanks! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 4, 2014 Share Posted February 4, 2014 Same thing happened to me this morning threw P0500 checked it with a pocket scanner had two codes I cleared the codes by disconnecting the battery. Will check if it comes back. Seems like it could be annoying to fix. Link to comment Share on other sites More sharing options...
Toallhisdoom Posted February 4, 2014 Author Share Posted February 4, 2014 Yea. Did the speedo stop working? I think if the speedo stops its the rear sensor. Front sensor is super easy to fix. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 4, 2014 Share Posted February 4, 2014 Yea. Did the speedo stop working? I think if the speedo stops its the rear sensor. Front sensor is super easy to fix. Thats the thing speedo is fine just rough low idle and still throws P0500. I cleared it twice once with the scanner the second time via battery disconnect. Drives fine as well. I guess that easy to fix sensor costs an ass load ? Link to comment Share on other sites More sharing options...
Toallhisdoom Posted February 4, 2014 Author Share Posted February 4, 2014 Around 110. Look on cl for someone parting one out. Take the front sensor out. Attach drill to the shaft. Attach volt meter to plug terminals and spin drill. If voltage goes up its good. Link to comment Share on other sites More sharing options...
