Headtrauma89 Posted January 20, 2014 Posted January 20, 2014 So, this may have been covered previously, but I didn't find a definitive answer. So I apologize if this is a repeat. I have a 97 L 5spd that I've pulled the blown motor out of. I have another 2.2 from an automatic that I'm planning to put into it. The automatic engine has egr where as the original 5spd motor did not. Will it be fine to just put it in leaving the egr in place? Will it just sit inactive? Or do I HAVE to swap the intake? I'd rather not swap the intake if I don't need to. The iac and all looks to be the same, the only difference I see is the egr system. Thanks.
johnegg Posted January 21, 2014 Posted January 21, 2014 swap the new engine as is (except for the fly wheel of course) the ECU is not looking for info from the EGR, so regardless of what the EGR is doing, the computer does not care. plug it in and play. good luck and happy motoring.
Headtrauma89 Posted January 21, 2014 Author Posted January 21, 2014 Thank you, that's what I suspected
r3v_v3ng3 Posted January 21, 2014 Posted January 21, 2014 You have to plug the egr port hole on the head. I had to cut the egr pipe that connected to the head and weld it shut on my friends impreza, unless you can find a bolt to plug it
Headtrauma89 Posted January 21, 2014 Author Posted January 21, 2014 If i was to swap the intake, then yes I would need to plug the hole.
r3v_v3ng3 Posted January 21, 2014 Posted January 21, 2014 Are you using an egr equipped engine to a non egr car? If so, you will need to plug the head since the egr pipe is connected to the head to the intake manifold.
johnegg Posted January 21, 2014 Posted January 21, 2014 not if he keeps the egr intake on the egr head and installs the engine whole. the egr pipe is in place , there are no open holes.
r3v_v3ng3 Posted January 21, 2014 Posted January 21, 2014 Got it, i thought the op was swapping the manifold out
86bratman Posted January 25, 2014 Posted January 25, 2014 In the event you want to get rid of the egr manifold, you can use an m16 oil drain plug from an auto parts store to plug the hole in the head. The one I got has a long magnetic end that I had to grind down to thread all the way into the head.
Headtrauma89 Posted January 26, 2014 Author Posted January 26, 2014 Update: So I got it installed in the car, and it ran great! No issues caused by the egr. Thanks again
