adj789 Posted January 16, 2014 Share Posted January 16, 2014 Start the car in the morning and it feels fine, idle is at ~1k, drive to the stop sign in my neighborhood and it starts to shake a little once I get to a complete stop, still idle at 1k, then I get to a light just outside my neighborhood and it starts shaking like a Chihuahua in February, still idle at 1k. The rest of the day it's fine even after work where it sits for 8 hours. Any ideas? Link to comment Share on other sites More sharing options...
ehsnils Posted January 16, 2014 Share Posted January 16, 2014 Manifold donut gaskets.MAF sensor cleaning. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted January 17, 2014 Share Posted January 17, 2014 Had the same issue for a while and then I eventually was throwing a p304 code and had a cel. I took it too the dealership and had them run a diagnostic. The technician changed the maf and swapped the injectors around, cleared the code and then all was well....... Well not exactly the code, the stutter, and the cel all came back. Long story short of shasing and hoping, I put in some new injectors and have not had a problem since. Link to comment Share on other sites More sharing options...
Nubie Posted January 17, 2014 Share Posted January 17, 2014 I've been having the same issue, bought some MAF cleaner today, gonna try tomorrow morning before I leave for work. I am also having the CEL same code for cyl 4 misfire, it used to be for cyl 3 then it changed. Thing is it's on one day then off for a few, then comes back. Anyway not my thread. I will report on the MAF cleaning. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 Just for the record, what's your DD like ? Short drive to work ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nubie Posted January 17, 2014 Share Posted January 17, 2014 Cleaned MAF, improved idle drastically. Thanks E Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 newbie's. That's a old fix. Have you replaced the o-rings yet between the intake manifold and the TGV's ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bjrongo Posted January 17, 2014 Share Posted January 17, 2014 I had the same experience on and off. Sometimes it just shakes on idle. Havent figured out why hopefully its not ruining my gal, havent had any codes or anything like that. Link to comment Share on other sites More sharing options...
Nubie Posted January 17, 2014 Share Posted January 17, 2014 No I have not, hmm ill search and check that out. Thank you. newbie's. That's a old fix. Have you replaced the o-rings yet between the intake manifold and the TGV's ? Link to comment Share on other sites More sharing options...
FunkyMonkey Posted January 17, 2014 Share Posted January 17, 2014 Nubie, I think there are some new orange rings that are larger for this application. You want them Link to comment Share on other sites More sharing options...
Max Capacity Posted January 17, 2014 Share Posted January 17, 2014 The o-rings usaully present a problem this time of year too. When you see the new o-rings next to the old ones you'll understand the problem. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
adj789 Posted January 18, 2014 Author Share Posted January 18, 2014 Just for the record, what's your DD like ? Short drive to work ? ya less than a mile Link to comment Share on other sites More sharing options...
AF_3C2 Posted January 18, 2014 Share Posted January 18, 2014 Mine seems to be doing the same thing, but always when idle, no matter how far/long I have driven it. When I test drove it out of the dealer, they just told me all LGTs from this era do it. Will try the MAF cleaner this next set of days I have off. IF that doesn't work, than o-rings will be next.... Link to comment Share on other sites More sharing options...
adj789 Posted January 19, 2014 Author Share Posted January 19, 2014 so is it pretty easy to DIY clean the MAF? is there a walkthrough here? I tried searching but didn't find anything Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 19, 2014 Share Posted January 19, 2014 http://legacygt.com/forums/showthread.php/clean-maf-153796.html?t=153796 Pull it out by removing the harness connector. Remove the two Phillips screws. Pull up on the sensor. Spray liberally into the channel, look closely there is an element up there that is what you really want to be sure is clean. Protect your eyeballs. J Don't go probing in there with a Qtip! Let air dry before putting back in the car. Link to comment Share on other sites More sharing options...
