klrtovfr Posted February 20, 2014 Share Posted February 20, 2014 Could be the obd reader, but seeing the front isnt that important unless you see a significant drop in mpg or rough running motor. Also since you have a california pzev, you have a catalytic converter with more precious metals and a stricter ecu range. So changing the exhaust flow is probably enough to get the oxygen levels out of range. You could buy a tactrix cable and delete the code from the ecu so that it never shows up. Link to comment Share on other sites More sharing options...
klrtovfr Posted February 20, 2014 Share Posted February 20, 2014 Also the front o2/af sensor wont fluctuate much because it is reading the actual A/F ratio and doesnt jump from lean to rich so if there is a display in torque for af ratio it would be pretty similar Link to comment Share on other sites More sharing options...
klrtovfr Posted February 21, 2014 Share Posted February 21, 2014 As you can see the front o2 AF sensor graphs the same as the measured AF Ratio so if you can get that then you dont need the front af sensor readings. Link to comment Share on other sites More sharing options...
Blue Shark Posted November 14, 2014 Share Posted November 14, 2014 I'm really concerned about throwing a CEL and ruining MPG. I just received UEL Ceramic Coated & Hi-Flow catted header but I think the Hi-Flow cat will be a problem with this. Link to comment Share on other sites More sharing options...
chrispyvu Posted November 15, 2014 Author Share Posted November 15, 2014 i'm sure youll be okay with a brand new one. i bought mine second hand and it seems the flanges to the block were both slightly warped and so it always had an annoying hissing leak and gaskets couldn't help seal it at all. i've since moved to a oem turbo manifold modified to fit and the o2 sensors relocated. the CEL stays off but comes on every once in a while but thats probably because we reused the old gaskets at time of install for some dumb reason. been too lazy to get around to changing them. good luck though! Link to comment Share on other sites More sharing options...
cwo715 Posted November 16, 2014 Share Posted November 16, 2014 If it becomes an issue, pick up the Tactrix cable and ecutek software. I debated dropping another ball for a header since I'm V1 but the cobb Catback was more on my mind lol. What I had to do to get the car to run right was full tank 91, reset ECU (pull fuse), then let the car calibrate but catch it before it tried to ready the sensors (around 3/4 tank line) then hooked up tactrix and disabled the code. Been about 4 months now, no hesitations, my O2 sensors are all at PASS, enabled the code for a day and nothing threw any errors but disabled again because my luck sucks I noticed with this header, running 87 tends to cause hesitation and jumpiness, shifting granny style you'll feel the car buck a little, running 91 or higher (w reset Ecu) seems to be the way to go, no issues what so ever. Link to comment Share on other sites More sharing options...
chrispyvu Posted November 17, 2014 Author Share Posted November 17, 2014 i never had any luck setting up the tactrix and ecutek software. i dont know if its because i didnt get the most current version of it or if i didnt set it up right or if i didnt get the current data files or something. i'd still like to disable the codes with the tactrix though, but i've given up on it for a loooooong time because i couldnt get the ecu to be read properly no matter what i tried. got any tips for me bruh ? thanks Link to comment Share on other sites More sharing options...
Blue Shark Posted November 17, 2014 Share Posted November 17, 2014 Ceramic Coated Hi Flow so far so good! Driven 30 miles on the highway and like 30 the other day and still no CEL. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 17, 2014 Share Posted November 17, 2014 i never had any luck setting up the tactrix and ecutek software. i dont know if its because i didnt get the most current version of it or if i didnt set it up right or if i didnt get the current data files or something. i'd still like to disable the codes with the tactrix though, but i've given up on it for a loooooong time because i couldnt get the ecu to be read properly no matter what i tried. got any tips for me bruh ? thanks If you follow the guide in the tuning section its about a 30 min process. For both my GT and 2.5i I disabled the P0420 DTC. Stock or modded it wil never be a problem again. Link to comment Share on other sites More sharing options...
chrispyvu Posted November 18, 2014 Author Share Posted November 18, 2014 it worked fine for you using the specific files from that post? i remember i tried all different sorts of combinations of latest and older definitions and still had no luck for the better part of a month back when i was actively trying. the fact of them all being a couple of years old doesnt help with finding a working combination either x.x Link to comment Share on other sites More sharing options...
Ritch2.5 Posted November 19, 2014 Share Posted November 19, 2014 so my 2.5 is a pzev. immediately after installing the headers i got a CEL and its been on ever sense. The 2 codes both read O2 sensors, assuming its because the 2 other cats get deleted before the sensor because it's a pzev, is there anyway i can fix this or am i screwed. I tried clearing it and it came back on once i start up my car Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 19, 2014 Share Posted November 19, 2014 it worked fine for you using the specific files from that post? i remember i tried all different sorts of combinations of latest and older definitions and still had no luck for the better part of a month back when i was actively trying. the fact of them all being a couple of years old doesnt help with finding a working combination either x.x The definition files are dated from a year or two ago b/c they havent changed they work as long as your ECM is supported which it should be, I followed his guide D/L the files put them in the proper locations, and I run Win7 on top of VM fusion on my MacPro. so my 2.5 is a pzev. immediately after installing the headers i got a CEL and its been on ever sense. The 2 codes both read O2 sensors, assuming its because the 2 other cats get deleted before the sensor because it's a pzev, is there anyway i can fix this or am i screwed. I tried clearing it and it came back on once i start up my car So PZEV or not you dont need to touch the actual map there is a DTC section of your stock ECM ROM that is represented by ECUFlash as a series of expandable list item like in your typical Windows explorer on your PC. What you do is open and disable them. The fix is simply to turn off the DTC your PZEV tuning is untouched. I bought a tactrix cable for this purpose alone, then ran over it, so I borrowed one but still if you buy a used one you can make that one change and sell it, everything else is free. Link to comment Share on other sites More sharing options...
Ritch2.5 Posted November 19, 2014 Share Posted November 19, 2014 Gee Otto is like a legend among these threads. Literally knows everything you'll need to know about a legacy or cars in general. anyway thank you. I vaguely remember people talking about the tactrix but remember hearing it was discontinued? the only thing i see on their site now is this which I'm assuming is just a wireless vision http://www.tactrix.com/components/com_virtuemart/shop_image/product/Tactrix_Openport_4b4437551be29.jpg with that said, just to clarify, this plus the software i should be able to go in and delete the setting which is throwing this CEL? on a scale of 1-10 how much of a computer guru do you need to be to understand it. Link to comment Share on other sites More sharing options...
chrispyvu Posted November 20, 2014 Author Share Posted November 20, 2014 it isnt wireless, you just have to plug in a mini usb cable into the other end of it which goes to your computer. and assuming you have no issues with setting up the actual software, then it sounds fairly straightfoward Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 25, 2014 Share Posted November 25, 2014 Once you have you file D/L from your ECM open it in ECUFlash scroll down and find the DTC section, check that box and highlight the "Enabled", then press (Ctrl and the + or - to enable or disable), Once you do that save the file under a different name and load it back to your ECU. While I was in here for my LGT i disable this and a few other codes like those damn air pump codes. For my 2.5i I disabled the P0420. Link to comment Share on other sites More sharing options...
cwo715 Posted November 26, 2014 Share Posted November 26, 2014 you'll notice that you start to clean your exhaust tips a little more often as well Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 1, 2014 Share Posted December 1, 2014 you'll notice that you start to clean your exhaust tips a little more often as well Very true! Link to comment Share on other sites More sharing options...
chrispyvu Posted December 28, 2014 Author Share Posted December 28, 2014 finally got around to tinkering with ecuflash and the tactrix more. followed steps from the link geeotto posted a couple posts back word for word and apparently i still don't have the right definitions after reading the rom from ecuflash? x.x can't figure out where i went wrong anymore screenshot attached Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 2, 2015 Share Posted January 2, 2015 What car do you have ? Link to comment Share on other sites More sharing options...
chrispyvu Posted January 3, 2015 Author Share Posted January 3, 2015 2009 2.5i pzev Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 4, 2015 Share Posted January 4, 2015 All i can say is it is really easy to mix up the definitions going into the right folder. Are you sure you have ECUFlash pointing to the right folder for the definition files? Link to comment Share on other sites More sharing options...
chrispyvu Posted January 5, 2015 Author Share Posted January 5, 2015 i have it pointed to the rommetadata/subaru folder which i replaced with the downloaded definition files from 10-07-09. completely stumped x.x Link to comment Share on other sites More sharing options...
