Johnny_I Posted January 12, 2014 Share Posted January 12, 2014 Is there a DIY rear brake job for our cars floating around? I went to replace my rear rotors and pads and I noticed the caliper carrier bolts are pretty much inaccessible... is there something I'm missing? Any and all help is appreciated. Thanks. Link to comment Share on other sites More sharing options...
doobaruGT Posted January 12, 2014 Share Posted January 12, 2014 They are very accessible. Perhaps you're eyeing up the wrong bolts. http://legacygt.com/forums/showthread.php/rear-brake-pad-replacement-147194.html Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2014 Share Posted January 12, 2014 14mm socket, 6" extension, I like to use my flex head ratchet with the long handle. Also PB Blaster is your best friend. Use 8mm bolts with some PB Blaster and anti seize compound to walk the rotors off the hubs. You may need to back off the parking brake shoes too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Johnny_I Posted January 14, 2014 Author Share Posted January 14, 2014 So pretty much I was looking down on the brakes from a seated position and didn't realized they had access holes if your underneath they are easily visible as compared to a seated position... chalk this up as Oops in my book. Sorry fellas but thank you for the prompt responses. Link to comment Share on other sites More sharing options...
